 訪客: 721
center   討論區主頁 » Four Thirds System and Olympus SLR » E-400 ccd Spec無發表權
發表時間: 2007-08-13 08:23
[30933] E-400 ccd Spec
[30934] Re: E-400 ccd Spec
看規格
http://www.kodak.com/US/en/dpq/site/SENSORS/name/KAI-10100_product/show/KAI-10100_productSpecifications
Frame Rate
Full resolution (FA mode)--------------------5 fps
1x2 bin (3760 x 1420) (FB2 mode)-------------10 fps
2x2 bin (1880 x 1420) (FB4 mode)-------------10 fps
4x4 bin (940 x 710) (FD16 mode)--------------19 fps
這片CCD有處理5 fps的能力,且縮圖時更可達10-19 fps。
但 E-400只能3 fps
The Kodak KAI-10100 Image Sensor is a 10-million pixel, 22.5mm diagonal [Four Thirds format] high performance color interline CCD image sensor. Advanced 4.75 micron square pixels provide outstanding sensitivity and dynamic range, and overflow protection is provided in each pixel through the use of a vertical overflow drain.
The sensor employs a 4-field interlaced design for full resolution readout, or can be read as a progressive scan device using 1x2, 2x2, or 4x4 color binning modes. Use of these color binning modes provides significantly improved sensitivity and faster readout rates, making this sensor ideal for both Scientific and Photographic applications.
Features
* High resolution with low noise
* High sensitivity and dynamic range
* On-sensor color binning for enhanced sensitivity and frame rate
* Electronic shutter
Applications
* Industrial inspection
* Scientific imaging
* Photography
Summary Specification
http://www.kodak.com/global/en/business/ISS/Products/Interline/KAI-10100/specs.jhtml?pq-path=12046/12100
參考
E-300/500 full-frame CCD KAF-8300
analcye
發表時間: 2007-08-13 08:47
註冊日: 2005-12-15
發表數: 150
[30935] Re: E400 ccd Spec
看規格
Frame Rate
但 E-400只能3 fps
那E-410跟E-510也是用這塊ccd囉?
發表時間: 2007-08-13 09:32
[30937] Re: E400 ccd Spec
E-410跟E-510是使用松下LiveMOS
