NIKON SLR
D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! | 無發表權 |
| ITO | 發表時間: 2012-03-11 21:09 |
[81815]
D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 根據Nikon 官網Q&A: D800 接 Nikkor PC-E 24mm f/3.5D ED 不能使用 移軸和傾斜 功能 nikonrumors.com Nikon support: Nikkor PC-E 24mm f/3.5D ED lens cannot be used with shifting and tilting on the D800 http://nikonrumors.com/2012/03/10/nikon-support-nikkor-pc-e-24mm-f3-5d-ed-lens-cannot-be-used-with-shifting-and-tilting-on-the-d800.aspx/ Nikon 官網Q&A http://answers.nikonusa.com/answers/7022/product/2168/nikon-pc-e-nikkor-24mm-f-3-5d-ed-questions-answers/questions.htm?expandquestion=648244 Question Will the 24 pc-e work with the new d800? Answers The lens is a standard Nikon F mount, it will definitely mount on a D800, unless Nikon has changed the type of mount their new camera bodies use and made all lenses obsolete. Whether the rectangle housing and the knobs interfere or not with the built-in flash housing of the D800, judging by the side-by-side photos of the D800 and D700 comparison, there may be slight limitations on shift movement. As for metering and focusing while tilted or shifted, most likely the D800 will not do so while tilted or shifted. Best Answer Social Answering Subscriber ------------------------------------------------------------------ Nikon PC-E Nikkor 24mm f/3.5D ED ??--發表 http://photofan.jp/camera/html/modules/newbb/viewtopic.php?viewmode=flat&topic_id=4537&forum=5 |
| ADI | 發表時間: 2012-03-11 21:20 |
[81818]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 怎麼會有這種事......
| flchang | 發表時間: 2012-03-11 21:34 |
Quite a regular ![]() ![]() 註冊日: 2007-02-09 來自: 發表數: 134
[81819]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 這真是太神奇了~~~
| PENTAKON | 發表時間: 2012-03-11 21:45 |
[81820]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 以前好像聽過有人說五菱鏡部位會卡到?
所以我一直認為D700,D800這個class的乾脆像5D那樣不要裝內閃。 應該要直接採用D個位數機的頭部造型才對。 |
| r16216 | 發表時間: 2012-03-11 22:18 |
[81821]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 引文:
贊成~ +1 最好是直接多開個電子接口 像OM-D那樣 做個機身供電的小閃來外接就可以了 需要的時候 從口袋拿出來像插USB一樣 一點也不費事 沒有必要一定得往軍艦部塞 而且最好是設計像SONY 20閃一樣可跳著打 20閃還要裝電池 機身供電的話 大概體積可以小一倍 |
| collective | 發表時間: 2012-03-11 22:37 |
版主 ![]() ![]() 註冊日: 2004-10-18 來自: 柏格方塊 發表數: 13198
[81823]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 這不是在搞笑嗎?
DX的機型也就算了,自家的FX機種也不行的話真的說不太過去. |
| charleswu | 發表時間: 2012-03-11 22:42 |
[81824]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 這種事原廠一定事前就清楚
搞不好是故意的,又是一種僱人怨的區隔手法 |
| ratoa | 發表時間: 2012-03-11 22:55 |
[81828]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 不擔心啦 韓國三隻羊不是也要出24mm的移軸鏡? nikon的移軸鏡… 不期不待 又太貴了!! |
| collective | 發表時間: 2012-03-11 22:57 |
[81830]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! D800/D800E的高畫素不就是要給人拿去拍風景的嗎?
這樣不能上移軸鏡頭是啥用意咧?真是OXXYZ..... 這樣我不會再三先二意了,TS-E,我來了..... |
| 9531816 | 發表時間: 2012-03-13 20:41 |
Quite a regular ![]() ![]() 註冊日: 2008-12-21 來自: 發表數: 80
[81875]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 已經有人做回應,在D800上面沒有問題Nikon Denies PC-E 24mm f/3.5 Lens Issues with the D800
| collective | 發表時間: 2012-04-24 17:55 |
[83233]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 原來是移軸(shift)的旋鈕會卡到,不要轉到這個角度是OK的
http://www.youtube.com/watch?v=nehkWWCRWZE |
| PENTAKON | 發表時間: 2012-04-24 19:27 |
[83234]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 是的。不是不能用,是會卡到導致使用上有限制。
這在D700就已經有發生了。不知為甚麼Nikon不改善 我覺得他們應該採用D3/D4那樣的造型。 或許Nikon認為用閃燈的人比用移軸鏡的人多吧 |
| collective | 發表時間: 2012-04-24 22:56 |
[83242]
Canon TS-E 24mm F3.5L II和17mm F4L的設計是一個比較小的Shift旋鈕,然後附上一個零件包,內有一顆螺絲及一個旋鈕套,並在說明書上建議若是使用5系列以上等級的機身可以江這個旋鈕套裝上去. |
| arno | 發表時間: 2013-05-06 18:30 |
Just popping in ![]() 註冊日: 2011-03-26 來自: 發表數: 2
[91964]
Re: D800不能使用Nikkor PC-E 24mm f/3.5D ED 移軸和傾斜 功能 !!! 三陽的這支....別考慮了,知道上市上週特地拜託認識的商家訂了一管,結果成像鬆軟白花近三萬,唉~~~又不好意思退,只好再訂支原廠的,但看站上攝友說不適用D800?...唉~~~D800不適用那想必D800E也一樣~~~苦喔!
| lyykiki | 發表時間: 2013-05-08 11:18 |
Not too shy to talk ![]() ![]() 註冊日: 2008-03-29 來自: 發表數: 23
[92009]
