討論區主頁 » NIKON SLR » Nikon D800E 官方建議搭配鏡頭 | 無發表權 |
Pussycat | 發表時間: 2012-02-19 04:10 |
Home away from home 註冊日: 2005-02-20 來自: North Taiwan 發表數: 995
[80951]
Nikon D800E 官方建議搭配鏡頭 Nikon technical guide:
http://www.nikonusa.com/en_US/o/Y6wrkA9OU_z04IreazIXl_22UII/PDF/D800_TechnicalGuide_En.pdf P.16 With cameras like the D800E, which are suited to visually complex subjects, it is important to get as much sharpness from the lens as possible. Contrast at the periphery of the image can generally be increased by choosing an aperture two or three stops from the maximum, although results will vary from lens to lens. Below are some of the lenses you can use for enhanced sharpness: AF-S NIKKOR 14–24 mm f/2.8G ED AF-S NIKKOR 24–70 mm f/2.8G ED AF-S NIKKOR 70–200 mm f/2.8G ED VR II AF-S NIKKOR 16–35 mm f/4G ED VR AF-S NIKKOR 24–120 mm f/4G ED VR AF-S NIKKOR 200–400 mm f/4G ED VR II AF-S NIKKOR 24 mm f/1.4G ED AF-S NIKKOR 35 mm f/1.4G AF-S NIKKOR 85 mm f/1.4G AF-S NIKKOR 200 mm f/2G ED VR II AF-S NIKKOR 300 mm f/2.8G ED VR II AF-S NIKKOR 400 mm f/2.8G ED VR AF-S NIKKOR 500 mm f/4G ED VR AF-S NIKKOR 600 mm f/4G ED VR AF-S Micro NIKKOR 60 mm f/2.8G ED (最便宜的就是它...約16K台幣) AF-S VR Micro-Nikkor 105 mm f/2.8G IF-ED 所以說沒有這些鏡皇的話可以省下三百美金買D800去了... (50mm F1.4G在角落哭泣中) |
monte920 | 發表時間: 2012-02-19 06:18 |
Home away from home 註冊日: 2007-05-24 來自: 發表數: 985
[80952]
Re: Nikon D800E 官方建議搭配鏡頭 列出來的鏡頭基本上是光圈全開時周邊解析度仍然還不錯的鏡頭. 如果沒有列出來的鏡頭Nikon建議你縮個兩,三級光圈來達到滿意的效果, 雖然結果會因不同的鏡頭而有不同.
collective | 發表時間: 2012-02-19 07:34 |
版主 註冊日: 2004-10-18 來自: 柏格方塊 發表數: 13126
[80953]
Re: Nikon D800E 官方建議搭配鏡頭 為啥成像圈超大的PC-E沒有入列呢
ITO | 發表時間: 2013-03-16 08:09 |
[91103]
Re: Nikon D800E 官方建議搭配鏡頭 dxomark.com 為挑鏡頭的D800推薦的鏡頭
Which lenses for your Nikon D800? http://www.dxomark.com/index.php/Publications/DxOMark-Reviews/Which-lenses-for-your-Nikon-D800/Nikon-D800-and-standard-lens-choices |
ITO | 發表時間: 2013-04-30 12:44 |
[91840]
Re: Nikon D800E 官方建議搭配鏡頭 Nikon D800E 官方建議搭配鏡頭
更新 nikonrumors.com Nikon published an updated list of recommended lenses for the D800E camera http://nikonrumors.com/2013/04/29/nikon-published-an-updated-list-of-recommended-lenses-for-the-d800e-camera.aspx/ http://nps.nikonimaging.com/technical_solutions/d800_d800e_tips/d800e/ http://www.nikon-image.com/products/camera/slr/digital/d800/catalogue/D800TG_%2810%2904.pdf AF-S NIKKOR 14-24mm f/2.8G ED AF-S NIKKOR 24-70mm f/2.8G ED AF-S NIKKOR 70-200mm f/2.8G ED VR II AF-S NIKKOR 70-200mm f/4G ED VR AF-S NIKKOR 16-35mm f/4G ED VR AF-S NIKKOR 24-85mm f/3.5-4.5G ED VR AF-S NIKKOR 24-120mm f/4G ED VR AF-S NIKKOR 200-400mm f/4G ED VR II AF-S NIKKOR 24mm f/1.4G ED AF-S NIKKOR 28mm f/1.8G AF-S NIKKOR 35mm f/1.4G AF-S NIKKOR 85mm f/1.4G AF-S NIKKOR 85mm f/1.8G AF-S NIKKOR 200mm f/2G ED VR II AF-S NIKKOR 300mm f/2.8G ED VR II AF-S NIKKOR 400mm f/2.8G ED VR AF-S NIKKOR 500mm f/4G ED VR AF-S NIKKOR 600mm f/4G ED VR AF-S Micro NIKKOR 60mm f/2.8G ED AF-S VR Micro-Nikkor 105mm f/2.8G IF-ED PC-E NIKKOR 24mm f/3.5D ED PC-E Micro NIKKOR 45mm f/2.8D ED PC-E Micro NIKKOR 85mm f/2.8D ------------------------------------------------------ 突然發現 新型 50mm f/1.8G 並沒有在名單內..... |
kshieh | 發表時間: 2013-04-30 14:44 |
Home away from home 註冊日: 2009-01-06 來自: 發表數: 322
[91843]
Re: Nikon D800E 官方建議搭配鏡頭 引文:
是因為太便宜嗎 奇怪的是24-85VR竟然上榜?是為了也把它當D800E的kit鏡背書嗎 |
ITO | 發表時間: 2013-07-18 12:42 |
[93714]
Nikon Rumors傳聞 Nikon added three more Nikkors to the list of recommended lenses for the D800E camera Read more on NikonRumors.com: http://nikonrumors.com/2013/07/16/nikon-added-three-more-nikkors-to-the-list-of-recommended-lenses-for-the-d800e-camera.aspx/#ixzz2ZMh1pWRg http://nikonrumors.com/2013/07/16/nikon-added-three-more-nikkors-to-the-list-of-recommended-lenses-for-the-d800e-camera.aspx/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+NikonRumors+%28NikonRumors.com%29 即將追加3隻鏡於名單上 AF-S NIKKOR 18-35mm f/3.5-4.5G ED AF-S NIKKOR 80-400mm f/4.5-5.6G ED VR AF-S NIKKOR 800mm f/5.6E FL ED VR |
collective | 發表時間: 2013-12-31 19:41 |
[98330]
Re: Nikon D800E 官方建議搭配鏡頭 小弟試過AF-S NIKKOR 50mm F1.4G,果然不太行,列入出清名單.....
