 訪客: 37
center   討論區主頁 » NIKON SLR » D3x 明天 12/1發表---發表了無發表權
發表時間: 2008-11-30 09:44
[51591] D3x 明天 12/1發表---發表了
nikonwatch.com
http://www.nikonwatch.com/2008/11/29/nikonpro-magazine-accidently-mailed-a-day-early/
打電話到Nikon UK 詢問的結果,
D3X 將於12月1日發表。
同時,刊載了D3X的產品資訊的Nikon Pro雜誌,
本是預定星期六發送預定星期一能送達,
由於出差錯提前被發出。
參考
http://photofan.jp/camera/html/modules/newbb/viewtopic.php?topic_id=4912&forum=5&post_id=51563#forumpost51563
PENTAKON 寫道:
D3X
Ultra-high definition 24.5-megapixel flagship takes DSLR into medium-format terrain
The professional SLR world has been transformed in just 12 months by the introduction of no less than four new Nikon pro SLR bodies. First we saw the D3 and D300. Then there was the D700. Now, with the launch of the D3x, Nikon offers more FX format pro cameras than any other manufacturer. At 24.5MP, the D3x has the highest resolution seen in a Nikon SLR to date.
The new camera shares all of the D3’s features, including Live View (making it the world’s highest resolution SLR with viewscreen shooting); the 51-point MultiCAM3500FX autofocus system; Scene Recognition System; Expeed 16-bit processing; 3-inch high-resolution 922.000-dot viewing screen; and the tough, weather-resistant magnesium body.
The D3x was designed with medium format photographic applications in mind. The ISO range covers 100-1600 with a Lo1 (equivalent to ISO 50) as well as boost settings up to the equivalent of ISO 6400.
But it’s also fast. The D3x can record its high-resolution 24.5MP files at up to 5fps. As with the D3, it has two alternative crop modes: 5:4 and DX In DX crop mode the camera captures 10MP files at up to 7fps.
The MultiCAM3500FX AF system is the same as the D3, and has the largest number of individually selectable focus points available, making this a very effective system for isolating fine details in the scene. The widely acclaimed Autofocus Tracking capabilities are, as you would expect, the same as the D3.
Pixel numbers alone do not guarantee good quality pictures. The D3x Expeed image-processing system is custom-designed to render this detail with levels of tonal gradation never before seen in a DSLR. Its 75MB files are ideally suited for stock photography and extremely high levels of enlargement.
And being a Nikon SLR, its body is much faster, intuitive to handle and ergonomically advanced than heavy and complex medium-format systems.
You’ll have guessed by now that the D3x is armed at photographers whose work requires the ultimate in detail and output quality Where skin tones, fabric textures, crisp edges, and foliage are paramount - in the fashion, commercial and landscape area - the D3x excels.
Beyond the confines of the studio lighting environment, the onboard exposure metenng and AWB systems make the D3x equally at home in less controlled lighting situations where the aim is to capture the atmosphere of ambient lighting.
FEATURES
THE SENSOR
The D3x has an exclusive 35.9 x 21mm (FX format) 24.5MP image sensor with unique OLPF (optical low pas filter) and high-speed channel readout. ISO range covers the equivalent of 50-6400.
IN FOCUS
The widely acclaimed speed and accuracy of the MultiCAM3500 AF system with 51-AF points. Individual selection assumes a new importance in combination with the high resolution: it’s easy to isolate and focus on small details in the scene.
SPEED AND RESPONSE
At full 24.5MP resolution, the D3x shoots at 5fps, 7fps is possible in DX Crop mode. The camera is as responsive as the superfast D3. 12ms start up with a shutter release lag time of just 41 ms (CIPA standard). It writes files to the dual CF slots at about 35MB per second.
IMAGE PROCESSING
The D3x’s 16-bit EXPEED engine is specially tuned to deliver detail-rich, colourful files with low levels of noise and high detail. It is also tuned to minimise the effects of colour fringing with older F-mount Nikkor lenses, and to minimise the effect of unnatural-looking (digital) noise patterns. Vignette (peripheral fall-off) can also be controlled for creative effect.
ACTIVE D-LIGHTING
The D3x features a new Extra High Active D-Lighting setting, designed to better manage extremely high-contrast scenes, especially tonal gradation in highlights.
SCENE RECOGNITION SYSTEM
Information from the 1005-pixel RGB sensor with diffraction grating is used to recognise the subject position and colour prior to capture. The results are then used by autofocus, auto exposure and auto white balance.
LIVE VIEW
The D3x is the highest resolution digital SLR yet to offer Live View. Allowing photographers to compose and shoot via the 3in monitor instead of the viewfinder brings a variety of practical advantages both in the studio and on location. Two modes are offered: Handheld and Tripod. Contrast-detect autofocus is available in Tripod mode.
MONITOR
3-inch wide-angle (170deg) rear viewing screen, with 922,000 dots, is ultra-high definition, and proven to exhibit extraordinary levels of damage resistance.
THE INTERFACES
USB 2.0 downloads images off the camera fast when tethered, and flexibly when connected with the WT-4 wireless transmitter. With both HDMI and AV/Out ports GPS data can be captured into the EXIF as before. The new, compact Nikon GP-1 GPS unit can also be attached via the 10-pin terminal and mounted in the hotshoe, or clip on the camera strap.
POWER MANAGEMENT
The D3x uses the same high performance lithium-ion battery (EN-EL4a) as the D3. Thanks to efficiencies in the camera’s onboard EXPEED image-processing system, battery performance is comparable with the D3.
THE BODY
Extremely durable magnesium construction with economically optimised and weather-sealed buttons, dials and LCD displays. Extensive use of high-grade rubber grips means the body is comfortable to handle for long periods of time, and in a wide range of temperatures.
Amin1126
發表時間: 2008-12-01 05:48
註冊日: 2004-12-09
發表數: 163
[51622] Re: D3x 明天 12/1發表
哈 等了快六個小時
希望有更好的消息 ︿-︿
發表時間: 2008-12-01 06:05
[51623] Re: D3x 明天 12/1發表
這台是準備好的
要追著5D II打的~
接下來就等D700跟D3降價了!~
真是等越久,省越多!~
停產前的商品最多便宜可以撿!~
victoryuy
發表時間: 2008-12-01 06:34
註冊日: 2006-07-11
發表數: 248
[51625] Re: D3x 明天 12/1發表
這台是準備好的
要追著5D II打的~
D3X要是拿來跟5DII比那可真是墮落
就只是為了頂級高畫素需求
要說也是和1DsmarkIII比吧
5DII用D700降價打比較適合
看對焦系統 像素 錄影综合其來差多少錢
目前nikon是估差10000左右就是(日本nikon的折價活動)
我是覺得還有空間可降 必竟先出 零件應該也和D300 D3有所重複
怎樣都要降在5DII前面
yuandchiu
發表時間: 2008-12-01 06:35
發表數: 453
[51626] Re: D3x 明天 12/1發表
這台是準備好的
要追著5D II打的~
接下來就等D700跟D3降價了!~
真是等越久,省越多!~
停產前的商品最多便宜可以撿!~
打不到吧,除非D3X一台不超過十二萬。
yuandchiu
發表時間: 2008-12-01 06:45
發表數: 453
[51629] Re: D3x 明天 12/1發表
要跟5DII打,降價不是辦法,直接出D700X比較實際。
發表時間: 2008-12-01 12:07
[51641] Re: D3x 明天 12/1發表
發表時間: 2008-12-01 12:12
[51642] Re: D3x 明天 12/1發表
感謝 PENTAKON兄資訊
日本地區 2008年12月19日上市
予定生産台数 初期月産 約2千台
官網samples
http://www.nikon-image.com/jpn/products/camera/slr/digital/d3x/sample.htm
_________________________________________________________________
株式会社ニコン(社長:苅谷 道郎)の子会社、株式会社ニコンイメージング
ジャパン(社長:西岡 隆男)は、ニコンが開発した35mmフィルムの画面サイズ
(36×24mm)に準じるニコンFXフォーマットCMOSセンサー(撮像サイズ 35.9×
24.0mm)を搭載し、有効画素数24.5メガピクセルの高精細、高画質を実現した
デジタル一眼レフカメラ「D3X」を発売します。
 「D3X」は、中判デジタルカメラ同等の極めて高精細な画像を提供し、プロ
ユーザー、特にスタジオでの高画質な撮影のニーズに応えます。高精細、高画
質が求められるファッションや商品撮影、大判ポスターなどの制作にも十分耐
える画質性能です。また、「D3」と共通のカメラボディーによって機動性、操
作性に優れ、屋外での撮影にも適しています。
・ニコンFXフォーマット、新開発CMOSセンサー(撮像サイズ 35.9×24.0mm)搭載
・有効画素数約 24.5メガピクセルの高画素
・中判デジタルカメラ同等の高精細、高画質
・24.5メガピクセル(FXフォーマット時)または20.4メガピクセル(5:4時)で
約5コマ/秒、10.5メガピクセル(DXフォーマット時)約7コマ/秒の高速連続
撮影※1
・ISO 100∼1600の広い常用撮像感度と優れた低ノイズ性能
・〔手持ち撮影〕、〔三脚撮影〕の2種類のライブビュー機能
・世界最多※2の高密度51ポイントAFシステム
※1:〔12ビット記録〕時
※2:デジタル一眼レフカメラとして(2008年12月1日現在 当社調べ)
●発売概要
商品名 デジタル一眼レフカメラ「ニコンD3X」
価格 オープンプライス
発売予定日 2008年12月19日
予定生産台数 当初月産 約2千台
●開発の背景
 ニコンが2007年11月に発売したデジタル一眼レフカメラ「D3」は、高画質・
高感度・高速性能で、多くのプロユーザーから絶大な評価を得ました。その後、
「D3」のさらなる高画素化への要望をお寄せいただきました。また、ファッシ
ョンや商品などのスタジオ撮影のプロユーザーからは、中判デジタルカメラに
匹敵する画質で、機動性、操作性に優れたカメラが強く求められていました。
 これらのご要望に対応するため、「D3」と共通のボディーを採用し、優れた
機動性、操作性を継承しながら、ニコンFXフォーマットCMOSセンサー(撮像
サイズ 35.9×24.0mm)を搭載し、有効画素数24.5メガピクセルの高画素を実現
した、デジタル一眼レフカメラ「D3X」を発売するにいたりました。
●主な特長
1. 有効画素数24.5メガピクセル。ニコンFXフォーマットCMOSセンサー搭載
 画面サイズ35.9×24.0mmの新開発ニコンFXフォーマットCMOSセンサーを搭載
し、有効画素数24.5メガピクセルの高画素を実現しました。さらに、画素特性
を最適化することで1画素ごとに取り込める光の量を十分に確保し、高いS/N比、
広いダイナミックレンジを実現。微細なディテールまで解像しながら、白とび、
黒つぶれの抑制、低ノイズ、なめらかな階調描写を可能にしています。
2. ISO 100からの広範な撮像感度
 常用撮像感度は、スタジオ撮影用のストロボのセッティングにマッチする
ISO 100から、高感度ISO 1600までと広範囲です。低感度設定時の高画質はもち
ろん、ISO 1600でもノイズの少ない高画質を実現しています。さらに、ISO 1600
に対し約2段(ISO 6400相当)までの増感、ISO 100に対し約1段(ISO 50相当)
までの減感ができ、幅広い撮影の可能性を提供します。また、撮像感度の自動
制御も可能です。
3. ニコン独自の包括的画像処理コンセプト「EXPEED(エクスピード)」に基づ
いた新開発画像処理システム
 ニコン独自の包括的デジタル画像処理コンセプト「EXPEED(エクスピード)」
に基づくテクノロジーを応用し、「D3X」に最適化した新しい画像処理プロセス
が高画質化、処理速度高速化、低消費電力化を実現しています。新開発の画像
処理エンジンは、色彩を問わない忠実な色再現、鮮やかな彩度、なめらかな階
調描写を実現しており、感じたままの色合い、色調の微妙な変化までも期待ど
おりに表現します。さらに、ノイズの発生自体を低減させるよう設計した先進
的なノイズ低減処理機能が、特に彩度に影響を及ぼすことなくノイズを最小限
にとどめます。
4. プロフェッショナルの要求に応える高速性能
 起動時間は「D3」と同じ約0.12秒※3。レリーズタイムラグも、「D3」と同様
ほぼメカニカルな限界と言われる約0.04秒※3 ※4 を達成しています。連続撮影
は撮像範囲がFXフォーマット(36×24)または5:4(30×24)時には約5コマ/秒、
DXフォーマット(24×16)時には約7コマ/秒の高速連続撮影※4 ※5 ができま
す。また、新世代高速カード(UDMA)に対応しており、「D3」同様のカード記
録速度35MByte/秒を達成。FXフォーマットで撮影された約7.1M(JPEG・画像
サイズL、画質モードNORMAL)のデータを毎秒約5コマ以上の速度で記録できます。
※3:CIPAガイドライン準拠
※4:〔12ビット記録〕時
※5:いずれも、カスタムメニューd2〔連続撮影速度〕で設定した連続撮影速度
になります。連続撮影速度は、フォーカスモードC、露出モードSまたはM、
1/250秒以上の高速シャッタースピードで、その他が初期設定のときの値
です。VRレンズ使用時にVR(手ブレ補正)機能をONにした場合、設定した
連続撮影速度で撮影できないことがあります。連続撮影速度を維持した
まま連続撮影できるコマ数には、画質モードなどによって上限があります。
5. 信頼度の高い自動制御を実現する「シーン認識システム」
「D3」同様、明るさだけでなく、被写体の色まで認識して高精度に露出を制
御する1005分割RGBセンサーのポテンシャルを有効に活用して、被写体や撮影
シーンの状況をカメラが撮影前に認識。その結果をAF、AE(自動露出)、スピード
ライトのi-TTL-BL調光、AWB(オートホワイトバランス)の制御に応用して高精度
を実現しています。
6. 高密度51点フォーカスポイント採用のAFシステム
「D3」で定評のあるマルチCAM3500FXオートフォーカスセンサーモジュールに
よるAFシステムを搭載しています。中央の15点のクロスタイプセンサーを含む
51点すべてのフォーカスポイントは開放F値5.6およびそれより明るいすべての
AF NIKKORレンズで有効です。シングルポイント/ダイナミック/オートエリアの
3つのAFエリアモードを搭載しており、被写体に即して選ぶことで51点のフォー
カスポイントを最大限に活用できます。さらに、「シーン認識システム」の
「被写体追尾」、「被写体判別」情報を利用して、ダイナミックAFモードの
被写体捕捉性能、オートエリアAFモードの人物への合焦率を向上させています。
7. 優れた耐久性
 外観カバー、シャシー、ミラーボックスに軽量かつ堅牢なマグネシウム合金
を使用しています。さらに、Оリングなどで接合部を厳重にシーリングし、高
い防滴・防塵性を実現しています。また、ニコンが開発したシャッターユニット
には炭素繊維とケブラーのハイブリッド新素材シャッター羽根を採用し、実装
状態で30万回のレリーズテストをクリアする高い耐久性を確保。同時に、シャ
ッターモニターの搭載により安定した精度を維持しています。
8. 高精細約92万ドット(VGA)、広視野角170°、強化ガラス採用の3型液晶モニター
 超高精細約92万ドット(VGA)で3型の大型液晶モニターを採用。再生画像の
拡大表示も極めて高精細で、ピントの確認も容易です。また、視野角が170°と
広く、ハイアングル、ローアングルのライブビュー撮影でも構図の確認が容易
にできます。
9. 2種類のライブビュー機能
〔手持ち撮影〕モードは撮影前の構図調整を目的としたモードで、通常のAF
撮影と同様に全フォーカスポイント51点を用いたTTL位相差検出方式AFでピント
合わせができます。
〔三脚撮影〕モードは三脚固定状態での厳密なピント合わせを目的とした
モードで、画面上の任意のポイントで、コントラストAFによるピント合わせが
できます。また、別売のソフトウェア「Camera Control Pro 2」を使えば、
パソコンのモニターで撮影画像を見ながらピント合わせやシャッターレリーズ
をコントロールできます。併せて、ワイヤレストランスミッター「WT-4(別売)」
を使用すれば無線での操作、画像転送も可能です。
10. ピクチャーコントロールシステム
「スタンダード」、「ニュートラル」、「ビビッド」および「モノクローム」
の4種の「ピクチャーコントロール」を用意しており、いずれかを選択してその
ままお使いいただくことも、それぞれの「ピクチャーコントロール」の画(え)
作り構成要素(輪郭強調・コントラスト・明るさ・色の濃さ・色合い)の設定
を好みに応じて調整してお使いいただくこともできます。オプションピクチャー
コントロールの「ポートレート」、「風景」、「D2XMODEⅠ」、「D2XMODEⅡ」、
「D2XMODEⅢ」も、無料ダウンロードしてカメラに搭載できます。
11. 見たままの明るさを再現するアクティブD-ライティング
コントラストの強い撮影状況下、マルチパターン測光との組み合わせでハイ
ライトの階調を活かして露出を決定し、撮影画像を解析して黒くつぶれる部分
をデジタル処理で明るく再現する「アクティブD-ライティング」。ダイナミック
レンジを単純に拡大する方式とは異なり、局所的な階調制御により軟調化を軽
減し、白とび、黒つぶれを改善しながら、適度なコントラストを保った画像を
提供します。撮影前の設定で「オート」、「より強め」、「強め」、「標準」、
「弱め」、「しない」を選べます。
12. デジタル水準器
カメラの傾きをボディーに内蔵した「加速度センサー」で検出し、左右方向
の傾き状態を背面液晶モニターに表示できます。ライブビュー時には液晶モニ
ターのスルー画に重ねて表示し、カメラが水平になっているかを、映像を見な
がら正確に確認できます。また、上面表示パネル、およびファインダー内表示
パネルの露出インジケーターに簡易表示もできます。
13. UDMA対応のメモリーカード ダブルスロット
コンパクトフラッシュカード(CFカード)のメモリーカードスロットは高速
データ転送ができるUDMAに対応。CFカードを2枚セットし、〔順次記録〕、
〔バックアップ記録〕、RAW画像とJPEG画像を別々のカードに記録する
〔RAW+JPEG分割記録〕のいずれかを選べます。また、〔画像コピー〕を選ぶと、
スロット間で記録画像のコピーができます。
14. 撮影時の位置情報などを記録するGPSユニット「GP-1」(別売)に対応
撮影時の緯度、経度、標高、日時が記録できます。地図情報と連携させて、
画像つきのオリジナルマップ作成などができます。
希望小売価格 21,000円(税込み 22,050円)
●その他の特長
・独自の画像処理で色のにじみを大幅に軽減し、画面の周辺までクリアに
描写する「倍率色収差軽減」
・画像周辺部の光量低下を効果的に軽減する「ヴィネットコントロール」
・視野率約100%※6、FXフォーマットで倍率約0.7倍※7を確保した光学ファインダー
※6:FXフォーマット時は上下左右約100%、DXフォーマット時は上下左右
約97%、5:4時は上下約100%・左右約97%。
※7:50mmf/1.4レンズ使用、∞、-1.0m-1のとき。
・「FXフォーマット(36×24)」、「DXフォーマット(24×16)」、
「5:4(30×24)」の3種類の撮像範囲
・フレキシブルに使えるファンクションボタン
・明るい場所に適した〔黒文字表示〕、暗い場所に適した〔白文字表示〕が
選べる撮影情報表示
・プロの厳密なピント合わせに対応したAF微調節機能
・ハイビジョンで画像が再生できるHDMITM規格に対応
・1コマ撮影モード時、付属のバッテリーEN-EL4a使用で、1回の充電で約4400
コマ※8の撮影が可能
※8:CIPA規格準拠。
發表時間: 2008-12-01 12:29
[51643] Re: D3x 明天 12/1發表
日本yodobashi
http://www.yodobashi.com/ec/product/100000001001068964/index.html
預約價:898,000日圓 10%還元
發表時間: 2008-12-01 12:33
[51645] Re: D3x 明天 12/1發表
發表時間: 2008-12-01 12:37
[51646] Re: D3x 明天 12/1發表
彼岸官網
http://www.nikon.com.cn/productitem.php?pid=1300-81707cab7d
* 2450 萬像素的尼康 FX 格式 CMOS 感應器
* 感光度範圍寬廣,最低為 ISO 100
* 新型EXPEED 數碼影像處理概念
* 高速拍攝的性能滿足最嚴格的專業需求
* 實現可靠的自動控制:場景識別系統
* 採用高密度 51 個對焦點的 AF 系統
* 優異的耐久性
* 高分辨率、 3 英吋 LCD 顯示屏,帶約 920,000 畫點(VGA), 170° 廣角和鋼化玻璃
* 提供兩種即時取景模式供選擇
* 優化校準系統
* 動態 D-Lighting —— 如您所見,重現色彩
* 電子虛擬水平
* 雙卡槽記憶卡兼容 UDMA
* GPS 裝置 GP-1(另購)
相機類型 數碼單鏡反光相機
有效像素 2,450萬
影像感應器 尼康 FX 格式 (35.9 x 24.0 mm) CMOS影像感應器;總像素: 2,572 萬;
影像尺寸(像素) FX 格式(36 x 24):6,048 x 4,032 [大],4,544 x 3,024 [中],3,024 x 2,016 [小] DX 格式(24 x 16):3,968 x 2,640 [大],2,976 x 1,976 [中],1,984 x 1,320 [小] 5:4 (30 x 24):5,056 x 4,032 [大],3,792 x 3,024 [中],2,528 x 2,016 [小]
感光度 ISO 100 到 1600,以 1/3、1/2 或 1 EV 步長調整;低於 ISO 100時,可以約 0.3、0.5、0.7 或 1 EV (相當於 ISO 50) 進行調節;高於 ISO 1600 時,可以約 0.3、0.5、0.7、1 EV(相當於 ISO 6400)進行調節。
存儲媒介 CompactFlash?(CF)卡 (I型)
液晶顯示器尺寸 3英吋
液晶顯示器 3 英吋,約 920,000 畫點 (VGA),170 °寬視角,亮度可調的低溫多晶硅 TFT LCD顯示屏
取景器型號 光學
電源要求 一塊可充點鋰電池 EN-EL4a/EL4,快速充電器 MH-22/MH-21,AC 適配器 EH-6(另購)
電池壽命 約 4,400 張
三腳架插孔 1/4 英吋 (ISO 1222)
體積 約 159.5 × 157 × 87.5 mm
重量(無電池) 約 1,220 g
提供附件 可充電鋰離子電池 EN-EL4a、快速充電器 MH-22、USB 線 UC-E4、AV 線 EG-D2、相機帶 AN-D3、機身蓋 BF-1A、配件熱靴蓋 Cap BS-2、目鏡 DK-17、電池蓋 BL-4、USB 線、Software Suite 安裝 CD-ROM 光盤
發表時間: 2008-12-01 12:51
[51647] Re: D3x 明天 12/1發表
哇!~~~
到底選哪一台好哩!~~~~
DTau
發表時間: 2008-12-01 13:03
註冊日: 2005-01-03
發表數: 9
[51649] Re: D3x 明天 12/1發表
官網的 sample 是我看過 C, N 相機以來, 最毒的了
發表時間: 2008-12-01 13:07
[51650] Re: D3x 明天 12/1發表
找遍日文官網介紹,未發現提到感光元件自動除塵功能。
不會是沒有感光元件自動除塵功能吧
Faust
發表時間: 2008-12-01 13:13
註冊日: 2005-01-20
發表數: 461
[51652] Re: D3x 明天 12/1發表
不會是沒有感光元件自動除塵功能吧
小弟用1Ds3有自動除塵功能,還不是塵點滿天飛..
進藤光
發表時間: 2008-12-01 13:25
註冊日: 2007-04-09
來自: https://www.insoler.com/
發表數: 207
[51654] Re: D3x 明天 12/1發表
既然如此,Canon上手難、問題多,不如把1Ds3黑貓給我,請浮爺還是回到心愛的Nikon D3X吧∼
發表時間: 2008-12-01 13:29
[51655] Re: D3x 明天 12/1發表
Faust 寫道:
不會是沒有感光元件自動除塵功能吧
所以Nikon就是不會做生意,裝一個當裝飾品不是也沒差嗎
發表時間: 2008-12-01 13:32
[51656] Re: D3x 明天 12/1發表
個人看法,
在Canon已經用5D Mark II宣告了下一代135 DSLR旗艦至少會有的功能水準後,Nikon D3X相對於D3,除了畫素的增加,還有什麼令人驚豔的嗎
發表時間: 2008-12-01 13:37
[51657] Re: D3x 明天 12/1發表
個人看法,
價格....
發表時間: 2008-12-01 13:56
[51658] Re: D3x 明天 12/1發表
(1) 2 3 4 ... 7 »
