bfung | 發表時間: 2008-09-05 23:53 |
Quite a regular ![]() ![]() 註冊日: 2006-02-04 來自: 發表數: 55
[47970]
Nikon的中幅機傳聞 http://www.nikonwatch.com/2008/09/04/nikon-digital-rangefinder-mx-format-medium-format-ish/ Nikon Digital Rangefinder? MX Format? Medium-Format-ish?! A little birdie passes along this really curious and especially informative rumor about Nikon having plans for what sounds like that old “modular” camera, but it also is a medium-format chip! Dear Matt FYI: On speaking with Nikon [in country unnamed], this came to light with various questions - they already had development plans for a new Nikon digital rangefinder with approx 48mmx48mm size sensor inside it, tentatively called the “MX” format, the camera is not to dissimilar to the older film Mamiya 6 camera philosophy. The new camera will be backward compatible with DX and FX lenses (via mount adaptor), therefore the lens factor (based on using a FX lens) will be worked out like this: DX = 1.5x (Half frame) FX = 1.0x (Full frame) MX = 0.5x Custom format choice: When shooting in FX mode with this camera, you will be able to “rotate” the sensor crop from landscape to portrait rather than turn the camera as well as be able to shoot the full square resolution this camera provides. options for 5:4 etc will also be available. Viewfinder/Live View: For more critical cropping (like for still-life and macro work) you will be able to use the live view function for exact framing rather than the rangefinder component. Sensor: about 48 megapixels, similar to the Nikon D3 design. Lenses: New range of lenses required for the full MX format, zoom option available covering different ranges on different formats, lenses relatively compact for format size. Summary A relatively compact traditional “medium format-esque” camera in a new camera line that will be aimed at studio, portrait, landscape and wedding photographers needs, with a more affordable price point than present larger format digital backs. This will allow the continuation of the D line as the sports and news photographers choice, expanding on the D3 with an upgrade to a 24mp sensor (hopefully available for the D3 body!) and future plans for 60 frame rate video recording modes in future models. Please keep my name, email and location anonymous. |
文包 | 發表時間: 2008-09-06 00:10 |
[47971]
Re: Nikon的中幅機傳聞 可以相容回FX/DX然後隨意裁切橫直幅
所以確定MX是6x6的規格了....? ![]() |
opass | 發表時間: 2008-09-06 00:42 |
[47972]
Re: Nikon的中幅機傳聞 我很希望Nikon也能出台MX格式可以裝120底片的機身耶
只拍數位不過癮 ![]() 搞不好Nikon推出的速度會比Pentax 645 digital還快 唉... |
cybermajor | 發表時間: 2008-09-08 12:06 |
Not too shy to talk ![]() ![]() 註冊日: 2005-08-05 來自: 發表數: 18
[48076]
Re: Nikon的中幅機傳聞 Nikon要出中幅數位系統真是勇氣可嘉,也值得鼓勵,只是這玩意到時候會落什麼價位,競爭市場鎖定在那一塊呢?
如果與P1等數位機背競爭,縱然有價格優勢,但除非做鏡頭(機背)相容,不然投資一套Nikon中幅應該也要花不少錢。 如果是與Canon全幅、特別是高畫素高價的1Ds3競爭,除了鏡頭不相容得買全套以外,價格能降到多低也是個問題。 當然還是很希望看到包括Nikon在內的各家相機廠比拼技術力就是了! |
ITO | 發表時間: 2008-09-17 00:56 |
[48891]
Re: Nikon的中幅機傳聞 nikonrumors.com
2則傳聞 http://nikonrumors.com/2008/09/14/post-in-a-forum.aspx http://nikonrumors.com/2008/09/15/mx-lenses.aspx AF-S MX Nikkor 24 f4.0G AF-S MX Nikkor 45 f2.8G AF-S MX NIkkor 85 f2.8G AF-S MX Nikkor 135 f2.0G ED AF-S MX Nikkor 200 F2.8G ED AF-S MX Nikkor 65-180 f2.8G ED IF |
raguna | 發表時間: 2008-09-17 11:24 |
[48931]
Re: Nikon的中幅機傳聞 AF-S MX Nikkor 24 f4.0G
這顆視角有多廣阿? |
ahock | 發表時間: 2008-09-17 11:41 |
Quite a regular ![]() ![]() 註冊日: 2006-05-11 來自: 發表數: 61
[48934]
Re: Nikon的中幅機傳聞 這一系列鏡頭,對應135的焦段應是:
15.6mm, 29.3mm, 55mm, 87.7mm, 130mm and 42-117mm. |
jenhoxen | 發表時間: 2008-09-17 19:04 |
[49031]
Re: Nikon的中幅機傳聞 如果真的重新製做一系列鏡頭, 規格似乎應有所突破, 改為一般人習慣的範圍,不再拘泥於過去120的那些焦段吧!(換算成135那麼怪異)
比方42-117,好好一顆中距鏡做成這個德行,能幹什麼呢→除了棚拍人像...但這樣又何須勞駕以機動性見長的Nikon來從頭生產呢,讓Pentax加個機背不就好了嗎? 我個人是覺得,Nikon要切入中片幅市場不是不可能,但一定得帶著既有的優勢而來,比方AF速度與精度、測光/白平衡、閃光系統制馭、運算速度等等在135系統已發展成熟、中片幅系統還很貧乏的技術,才能闖出一片天. 訴求對象既有一大部分來自原本熟悉135系統,對品牌有認同的消費者.在鏡頭的規畫上,目標客群會希望熟悉的規格(例如[大三元])有對應性產品出來,而不是仿製120過去那些[不方便]的規格! |
collective | 發表時間: 2008-09-17 19:16 |
[49034]
Re: Nikon的中幅機傳聞 引文:
可是,那會多大一支啊 ![]() 會用中片幅的,使用習慣會跟慣用135片幅的一樣嗎 ![]() |
華戈爾 | 發表時間: 2008-09-17 19:21 |
[49035]
Re: Nikon的中幅機傳聞 我覺得有沒有可能反光鏡拿掉,用現有接環鏡頭,
感光元件改成36mmX36mm,會不會比較容易達成, 我記得以前就有數位機背組就是有用nikon的鏡頭, 而且好像有不少家出品 |
collective | 發表時間: 2008-09-17 19:25 |
[49037]
Re: Nikon的中幅機傳聞 引文:
36mmX36mm的對角線(成像圈)和36mmX24mm的對角線圈(成像圈)是不一樣的,這想法好像不成 ![]() |
0100500 | 發表時間: 2008-09-17 22:39 |
Just can't stay away ![]() ![]() 註冊日: 2005-01-19 來自: 發表數: 211
[49063]
Re: Nikon的中幅機傳聞 記得nikon 好像有出鏡頭給大片幅(4X5)的樣子
只是不曉得是專為4X5的設計? 還是拿135改的? 印象中焦長都已經到中望遠的樣子(100mm) 拍謝 這個資料是小弟印象可能有失真的可能... ![]() |
華戈爾 | 發表時間: 2008-09-17 22:51 |
[49067]
Re: Nikon的中幅機傳聞 引文:
是大型機專用的不是135改的, 150mm的鏡頭對45機來說只能算標準鏡頭 ![]() |
Ric | 發表時間: 2008-09-17 23:04 |
[49068]
Re: Nikon的中幅機傳聞 我覺得中片幅應該還沒那麼快
因為以往底片的化學成份粒子大小固定,所以片幅和出圖可放大率之間的關係是固定的 現在感光元件可以在同樣大小內塞數量不同的畫素,出圖大小和片幅比較沒有太大的關連 在理想狀況之下(雜訊小/受光率高/鏡頭解析度高),只要畫素夠多,就可以具有大圖輸出的能力 以目前 135FF/APS 的片幅來說,畫素戰似乎還看不到極限 而且馬賽克打完,還可以打三層,或是多感光元件戰 而上述這些戰爭是單純只要在感光元件上做處理,並不需要去花功夫進入另一個接環系統 再加上 Nikon 目前還沒有進入 135FF 高畫素戰爭 所以我認為這個 Nikon 120FF 蠻值得懷疑的 ![]() |
lordcolus | 發表時間: 2008-09-17 23:08 |
Not too shy to talk ![]() ![]() 註冊日: 2005-08-03 來自: 發表數: 29
[49070]
Re: Nikon的中幅機傳聞 引文:
這樣的鏡頭規格真的是為中片幅設計的嗎? 廣角端和望遠端的光圈都大的嚇死人! Nikon之前有幫Bronica出過一系列66片幅的鏡頭 真的要進入120市場 應該也不算從零開始 |
victoryuy | 發表時間: 2008-09-17 23:53 |
[49077]
Re: Nikon的中幅機傳聞 引文:
這看起來還真像135的鏡頭 24~85 跟之前出的PC鏡一樣 雖然24的光圈不對 而且都是D鏡 或者是新定焦 不過24 85這兩顆光圈就小了點 45mm不就是餅乾?(學olympus?) 65-180比較像DX鏡 我是覺得應該是唬爛的啦 畢竟在其他片幅何必加G呢? 也只有135才需要加G表示沒光圈環 |
ross_tt | 發表時間: 2008-09-18 11:13 |
Quite a regular ![]() ![]() 註冊日: 2006-06-11 來自: Taiwan 發表數: 146
[49144]
Re: Nikon的中幅機傳聞 引文:
應該不能說是幫 Bronica 出的,那是 Bronica 跟 Nikon 買的。其實早期 Nikon 就是一家專業鏡頭廠,是後來才出自己的機身。 ![]() |
