 訪客: 78
center   討論區主頁 » NIKON SLR » Nikon D90 圖片和資料---發表無發表權
bfung
發表時間: 2008-08-26 13:36
註冊日: 2006-02-04
發表數: 55
[47363] Nikon D90 圖片和資料---發表
http://nikonrumors.com/2008/08/25/enjoy--official-d90-pictures.aspx
Specs (100% legit):
Video recording
12,3 Mpx.
ISO 200-3.200 plus Lo1 (100) and Hi 1 (6.400)
3" 900.000 dots LCD
11 AF points
Live-View, AF contrast, Face detection
Matrix sensor for metering 420 pixels RGB
Powerful speaker (for video in review mode)
AF-S DX 18-105 mm f/3,5-5,6G ED VR
15 elements/11 groups
1 aspherical
1 ED
1 Hybrid Asph.
Minimum focus: 0,45 m
Diaph. blades: 7
su0114
發表時間: 2008-08-26 14:35
註冊日: 2006-12-04
發表數: 319
[47370] Re: Nikon D90 圖片和資料
其實我很好奇錄影的功能對焦是怎麼對的
應該是對比對焦吧,還是手動對焦(手動對焦就麻煩了)
如果對比對焦是d300那種雞肋,那就不實用了,對焦太慢了
如果有啥米新的對焦方式出現,是不是代表,LV的實用性也增加了。
那O跟P拼命發展的對比對焦跟搭配對比對焦的鏡頭......最後的命運??
我相信這個是把DC的對焦方式在可交換鏡頭上面的實現,只是怎麼做,跟一般DC到底是差在哪裡,到現在我還是不太清楚,等機器有了之後再評斷吧!!
bfung
發表時間: 2008-08-27 02:33
註冊日: 2006-02-04
發表數: 55
[47391] Re: Nikon D90 圖片和資料
Nikon D90 specs:
12.3-megapixel CMOS sensor: This Nikon D90 camera body features a DX-format CMOS image sensor that provides the highest level of performance. Its integrated A/D converter enables selection between 12-bit and 14-bit conversions. The sensor design supports the broad light sensitivity range of ISO 200 to ISO 3200, and features refined high-ISO noise reduction.
3.0" LCD monitor: A high-resolution, super-density, 920,000-dot LCD monitor makes critical image review possible. This monitor also allows ultra-wide, 170-degree viewing in all directions.
Live view: You’ll also have a live preview of your subject, giving you point-and-shoot feel with the quality of a DSLR.
11-area AF: The sensor module offers an 11-area AF that ensures consistently fast and precise focus lock under varying shooting conditions. The wide area AF system gives greater compositional freedom when shooting sports and action.
4.5fps continuous shooting: Capture fast action and fleeting expressions. The D90 can shoot up to 4.5 frames per second.
Scene Recognition System: This system recognizes subject and scene conditions prior to capturing the shot. Enjoy improved subject tracking and subject identification for rapid and accurate focus area selection. Highlight analysis optimizes auto exposure by providing more accurate control. Light source inference studies both subject and pattern to achieve optimal white balance.
HD movie mode: Capture your surroundings in cinematic quality. The D90 features the D-Movie mode, which shoots HD movie with sound at 24fps.
D-Lighting enhancement: This technology compensates for underexposed images or insufficient flash by automatically adding light and detail to selected shots where needed, without affecting properly exposed areas.
In-camera editing menu: The in-camera editing features include Nikon D-lighting (that adds light and detail to selected shots only where needed), red-eye correction, image trimming, image overlay, monochrome black and white, sepia and cyanotype along with skylight, warm tone and custom color filter effects.
Lens included: You'll be ready to go in no time with the included 5.8x AF-S DX NIKKOR 18-105mm f/3.5-5.6G ED VR lens.
Fusing 12.3-megapixel image quality inherited from the award-winning D300 with groundbreaking features, including Live View and a cinematic-quality 24-fps D-Movie Mode, the Nikon D90 exceeds the demands of passionate photographers. Outfit includes the 5.8x, AF-S DX NIKKOR 18-105mm f/3.5-5.6G ED lens with VR image stabilization and legendary NIKKOR optical quality.
ENGINEERED FOR ARTISTRY. UNLEASH YOUR POTENTIAL.
• 12.3-effective megapixel DX-format CMOS imaging sensor
• 5.8x AF-S DX NIKKOR 18-105mm f/3.5-5.6G ED VR lens included
• D-Movie Mode — Cinematic 24fps HD with sound
• One-button Live View
• Continuous shooting as fast as 4.5 frames per second
• Continuous shooting as fast as 4.5 frames-per-second
• Low noise ISO sensitivity from 200 to 3200
• 3-inch super-density 920,000-dot color LCD monitor
• Built-in image sensor cleaning
• 11-point AF system with Face Priority
• Nikon 3D Color Matrix Metering II with Scene Recognition System
• Comprehensive exposure control
• Auto Active D-lighting
• Shutter precision and durability
• In-Camera Image Editing
• GPS geo-tagging
Sensor
Megapixels ?
Megapixels: 12.3
CCDs are the chips inside digital cameras that record photos. This refers to the number of pixels a CCD assigns to a photo.
View full glossary
close window
Megapixels: CCDs are the chips inside digital cameras that record photos. This refers to the number of pixels a CCD assigns to a photo.
12.3
Maximum resolution Info unavailable
Sensor type CMOS
Sensor size Info unavailable
Display
LCD screen size ?
LCD screen size: 3.0"
LCD screens allow you to frame, playback, and edit whatever you're shooting without looking through an eyepiece.
View full glossary
close window
LCD screen size: LCD screens allow you to frame, playback, and edit whatever you're shooting without looking through an eyepiece.
3.0"
Display type High-resolution LCD
Display resolution 920,000 pixels
Performance
Maximum shutter speed Info unavailable
Minimum shutter speed Info unavailable
Start-up speed Info unavailable
Focus type 11-area auto-focus
Image stabilization ?
Image stabilization: Yes, in included lens
Electronic and optical image stabilization systems compensate for normal hand shakiness and movement for clearer pictures and smoother videos.
View full glossary
close window
Image stabilization: Electronic and optical image stabilization systems compensate for normal hand shakiness and movement for clearer pictures and smoother videos.
ISO range 200-3200
Viewfinder
Magnification Info unavailable
Coverage Info unavailable
Convenience
Built-in Memory (M N/A
Live preview Yes
Self-cleaning sensor Yes
Red-eye reduction Yes
PictBridge-enabled Info unavailable
Memory card type N/A
Flash type Info unavailable
General features
UPC 018208254484
Manufacturer's part number D90KIT18105VR
發表時間: 2008-08-27 12:16
[47405] Re: Nikon D90 圖片和資料---發表
Imaging-Resouce 偷跑了
http://www.imaging-resource.com/NEWS/1219809660.html
有正式的大圖,包括 AFS 18-105mm F3.5/F5.6 VR 的照片
rigel
發表時間: 2008-08-27 12:26
註冊日: 2005-07-15
發表數: 49
[47407] Re: Nikon D90 圖片和資料---發表
dpreview 出來了!
Nikon D90
elf0724
發表時間: 2008-08-27 12:39
註冊日: 2007-06-22
來自: Taipei,Tainan
發表數: 497
[47408] Re: Nikon D90 圖片和資料---發表
影片拍攝樣本
http://chsv.nikon-image.com/jpn/products/camera/slr/digital/d90/dmovie/movie1.html
看起來是可以拍出淺景深的
不知對DV界會產生什麼樣的衝擊
raguna
發表時間: 2008-08-27 13:02
註冊日: 2007-08-17
發表數: 286
[47409] Re: Nikon D90 圖片和資料---發表
很不錯呢,搭配18-250的鏡頭就很不錯用,只是光圈小了點就是了,dv強項也不少啦,體積小,光圈大,明暗調節與重新對焦的即時反應快速,如果d90的即時反應夠快的話或許能取代dv
看來d90無法自動重新對焦,若能外接高解析度螢幕的話手動對焦不是問題,畢竟玩高階攝影機的都還是得手動對焦
倒是35mm轉換器可能要賣不出去了 ^^|||
雖然35mm轉換器可以轉換全片幅的畫面(更淺的景深)但代價跟d90比起來還是高不少
發表時間: 2008-08-27 14:06
[47414] Re: Nikon D90 圖片和資料---發表
Nikon D90 日本地區發表
http://www.nikon.co.jp/main/jpn/whatsnew/2008/0827_d90_01.htm
http://www.nikon-image.com/jpn/products/camera/slr/digital/d90/index.htm
samples
http://www.nikon-image.com/jpn/products/camera/slr/digital/d90/sample.htm
9月19日上市
預定生產台數初期月產約12萬台
D90接AF-S DX NIKKOR 18-105mm f/3.5-5.6G ED VR時
GPS配件「GP-1」
裝上垂直把手MB-D80時
ross_tt
發表時間: 2008-08-27 14:35
註冊日: 2006-06-11
發表數: 146
[47416] Re: Nikon D90 圖片和資料---發表
ITO 兄的手腳真快!
發表時間: 2008-08-27 14:44
[47417] Re: Nikon D90 圖片和資料---發表
中國Nikon官網
http://www.nikon.com.cn/productitem.php?pid=1281-86d7b52026
主要特點
* 全新設計的擁有低噪點、寬廣ISO感光度範圍的尼康DX格式CMOS影像傳感器
* EXPEED技術提供平滑的色調、飽滿的色彩及精美的細節
* 創新的DSLR短片功能:D-Movie(數碼短片)
* 帶有臉部檢測系統的場景識別系統
* 方便使用的即時取景模式
* 優化校準系統:自定義您的影像風格
* 動態D-Lighting功能:在高對比度光照下提供平滑色調還原
* 實用的多功能11點自動對焦系統
* 畫面覆蓋率約96%的高亮度五稜鏡取景器
* 先進的場景模式帶來出眾的影像質量
* 相機內潤飾菜單中廣泛的選擇項
* 精確度和耐用性設計
規格
相機類型---數碼單鏡反光相機
有效像素---1,230 萬
影像感應器---Nikon DX 格式 (23.6 x 15.8 mm) CMOS 感應器
影像尺寸(像素)--- 4,288 x 2,848 [L], 3,216 x 2,136 [M], 2,144 x 1,424 [S]; 數碼短片: 1240 x 720 / 24fps, 640 x 424 / 24fps, 320 x 216 / 24fps
感光度---ISO 200 至 3200,以 1/3 EV 為步長調校;ISO 200以下時,感光度以約 0.3、0.7 或 1 EV (ISO 100相當值)作定級遞減;高於ISO3200 時,感光度以約0.3、0.7或 1 EV(ISO 6400 相當值)作定級遞增。
文件格式---NEF; JPEG; AVI
存儲媒介---SD 存儲卡,兼容 SDHC
拍攝模式---1)單張拍攝 2)低速連拍 3)高速連拍 4)自拍 5)延時遙控 6)快速響應 7)數碼短片
白平衡---自動(具有主影像傳感器和 420 區 RGB 傳感器的 TTL 白平衡);帶有微調的12 種手動模式;色溫設定;預設手動白平衡;白平衡包圍
液晶顯示器 3英吋、約 92 萬畫點(VGA)、約 170° 視角的低溫多晶硅 TFT LCD 顯示屏
重放功能---支持變焦播放的全屏和縮略圖 (4、9 或 72 張影像或日曆) 播放、短片播放、Pictmotion 、幻燈播放、直方圖顯示、高亮顯示、自動旋轉影像及影像註釋 (最長可達 36 個字符)
刪除功能---1)格式化卡 2)全部刪除 3)選擇刪除
界面---USB 2.0 (高速): Mass Storage和MTP/PTP, GP-1
影像角度---約1.5倍鏡頭焦距
取景器---眼平五稜鏡單鏡頭反光取景器
對焦屏---帶對焦框的B型光亮磨砂對焦屏Mark II(可顯示取景網格)
取景器覆蓋畫面範圍/放大率---約96%/ 約0.94倍
自動對焦---尼康 Multi-CAM 1000 自動對焦模塊具備 TTL 相位偵測,11 個對焦點(包括 1 個十字型傳感器)和自動對焦輔助照明燈(範圍約為 0.5-3 m)
對焦模式---1)自動對焦(AF): 單次伺服AF(AF-S); 連續伺服AF(AF-C); 自動伺服AF(AF-A), 2) 手動對焦(M) 可從11種對焦點選擇
測光模式 1) 矩陣測光: 3D 彩色矩陣測光 II (G型和D型鏡頭); 彩色矩陣測光 II (其他 CPU 鏡頭) 2) 中央重點測光: 約 75% 的比重分佈於畫面中央的 6、8 或 10mm 直徑圓形內 3) 點測光:集中在以選定對焦點為中心的 3.5mm 直徑圈中(約為畫面的 2%)
測光表範圍---1) 0-20 EV(矩陣或中心重點測光), 2) 2-20 EV(點測光)
曝光控制---自動模式 (自動,自動 [閃光燈關閉]),場景模式(人像、風景、運動、近攝、夜間人像),帶柔性程序的程序自動模式 (P),快門優先自動模式 (S),光圈優先自動模式 (A), 手動 (M)
自動曝光 補償:在 ±5 EV 範圍內以 1/3 EV 或 1/2 EV 步長微調包圍:1/3、1/2、2/3、1 或 2 EV定級調校內的 2 至 3 次曝光
最大快門---1/4000
最小快門---30
快門---1/4,000 - 30 秒範圍 (以 1/3 或 1/2 EV 為步長調校,B門
同步連接---X = 1/200 秒;在 1/200 秒或以下速度時,與快門保持同步
閃光控制 1)TTL:使用 420 區 RGB 傳感器進行針對數碼單反相機 i-TTL 均衡補充閃光和標準 i-TTL 閃光,這些方式適用於內置閃光燈和SB-900、SB-600 或 SB-400 閃光燈 2) 自動光圈:適用於 SB-900 閃光燈及 CPU 鏡頭 3) 非 TTL 自動閃光: 支持 SB-900、SB-28、SB-27 或 SB-22s 閃光燈組件 4) 距離優先手動: 適用於 SB-900
閃光同步模式---前簾同步、慢速同步、後簾同步、減輕紅眼、減輕紅眼慢速同步
自拍---可選擇2秒、5秒、10秒 和 20 秒延時
景深預覽鈕---有
遙控---無線遙控其 ML-L3 (另購)
GPS---GPS 單元 GP-1(另購)
支持語言---中文(簡體和繁體), 丹麥語,荷蘭語, 英語, 芬蘭語, 法語, 德語, 意大利語, 日語, 韓語, 挪威語,波蘭語, 葡萄牙語, 俄語, 西班牙語和瑞典語
電源要求---1節EN-EL3e 鋰離子充電電池, 交流電源適配器 EH-5a (另購)
電池壽命---約1,000張
三腳架插孔---1/4 英吋 (ISO1222)
體積---約 132 x 103 x 77mm
重量---(無電池) 約 620g
提供附件---可充電鋰離子電池 EN-EL3e,快速充電器 MH-18a, 目鏡蓋 DK-5,橡膠眼罩 DK-21, USB 連接線 UC-E4,音頻/視頻線 EG-D2,相機背帶 AN-DC1,LCD 顯示屏蓋 BM-10,機身罩,配件熱靴蓋 BS-1, Software Suite CD-ROM 光盤
其他特點---潤飾菜單, LCD信息顯示, 除塵系統, 即時取景 (臉部優先AF), 數碼短片
su0114
註冊日: 2006-12-04
發表數: 319
[47418] Re: Nikon D90 圖片和資料---發表
還是沒有人跟我有相同的疑問嗎,錄影是自動對焦ㄇ?
光看影片看不出來是不是自動對焦,只知道有淺景深@@,應該是手動對焦ㄇ?
發表時間: 2008-08-27 14:48
[47419] Re: Nikon D90 圖片和資料---發表
假如 D90 的對比AF性能與D3/D700的對比AF性能差不多的話,
D90錄影即使可AF,也是速度極慢
發表時間: 2008-08-27 14:51
[47420] Re: Nikon D90 圖片和資料---發表
ross_tt 寫道:
ITO 兄的手腳真快!
其實有收到Nikon新聞稿,但根本沒時間譯
elf0724
發表時間: 2008-08-27 14:54
註冊日: 2007-06-22
來自: Taipei,Tainan
發表數: 497
[47422] Re: Nikon D90 圖片和資料---發表
應該是手動對焦
其實也不會有太大的不方便
影片拍攝大約70%的畫面應該是會以固定鏡頭完成
拉遠拉近的zoom in、zoom out
還有左右移動的Pan畫面大概只佔30%
許多電影所拍的淺景深表現手法也是得用手動對焦才行
題外話
如果說能夠達成Live View即有可能達成錄影功能
那不知Olympus未來有沒有可能以韌體升級的方式讓現行E-5X0、4X0也具備錄影功能呢?
su0114
發表時間: 2008-08-27 14:58
註冊日: 2006-12-04
發表數: 319
[47424] Re: Nikon D90 圖片和資料---發表
elf0724 寫道:
應該是手動對焦
其實也不會有太大的不方便
還有左右移動的Pan畫面大概只佔30%
題外話
可以升級就不是商人了,而是慈善團體了!!
上面的是開玩笑拉,應該是有差別於錄影的壓縮跟解壓縮晶片吧!!更何況還缺了聲音
raguna
發表時間: 2008-08-27 15:06
註冊日: 2007-08-17
發表數: 286
[47426] Re: Nikon D90 圖片和資料---發表
難說喔,之前minolta dimage 7也有升級的,變成可錄音
阿...好像沒有變有錄音,只有效能提升的樣子
發表時間: 2008-08-27 15:07
[47427] Re: Nikon D90 圖片和資料---發表
本來看D90規格很吸引人...不過看到錄影要MF就軟掉了 而且錄音只有mono(沒AC3至少來個stereo MPEG audio嘛)
看看Olympus E-30特地選在D90之後發表, 會不會端牛肉出來
elf0724
發表時間: 2008-08-27 15:10
註冊日: 2007-06-22
來自: Taipei,Tainan
發表數: 497
[47429] Re: Nikon D90 圖片和資料---發表
su0114 寫道:
哈哈
su0114兄說的也對
我忘記關鍵的硬體晶片了
沒有聲音無妨
無法即時壓縮就真的難解了
還是等待Micro 4/3系統的新機
希望支援轉接老鏡也能拍攝影片
很想看看Olympus Zuiko 50mm F1.4拍出來的影片效果啊
su0114
發表時間: 2008-08-27 15:22
註冊日: 2006-12-04
發表數: 319
[47430] Re: Nikon D90 圖片和資料---發表
剛剛看了討論,居然鏡頭防手震錄影也可以用@@
好樣的!!
simon1101
發表時間: 2008-08-27 15:55
註冊日: 2006-02-02
發表數: 111
[47433] Re: Nikon D90 圖片和資料---發表
官方部分展示影片的幕後花絮
http://www.youtube.com/watch?v=HVQX1rC-fRA&eurl=
(1) 2 3 4 ... 7 »
