 訪客: 347
center   討論區主頁 » NIKON SLR » PC-E Micro NIKKOR 45mm f/2.8D ED無發表權
發表時間: 2008-06-27 17:02
[45053] PC-E Micro NIKKOR 45mm f/2.8D ED
Nikon原廠鏡頭型錄中
http://imaging.nikon.com/products/imaging/lineup/brochure/index.htm
已刊登
PC-E Micro NIKKOR 85mm f/2.8D
http://imaging.nikon.com/products/imaging/lineup/lens/pdf/nikkor_lenses_36p.pdf
Normal lens with Perspective Control and macro capability
• Wide shifting and tilting range (shift: ±11.5mm; tilt: ±8.5°)
• ±90° lens revolving capability for versatile tilt/shift effects
• Maximum reproduction ratio of 1/2 (at 0.253m/0.83 ft.)
• ED glass element
• Nano Crystal Coat reduces ghost and flare for clear images
• Nine-blade rounded diaphragm
• Auto aperture control with electromagnetic diaphragm (with D3 and D300)
Lens construction: 9 elements in 8 groups
Closest focusing: 0.253m/0.83 ft.
Picture angle with Nikon DX Format:
35mm (135) format equivalent to 67.5mm
Filter attachment size: 77mm
Hood: HB-43
Dimensions: Approx. 82.5 x 112mm
Weight: Approx. 740g
other cameras, there are limitations in tilt/shift operation.
The Nikon F90X series, F90 series, F70, F60D, F55, F50D, F-401 series, F-801 series, F-601, F-601M, F3AF, F-501,
PRONEA S or MF cameras cannot be used.
發表時間: 2008-06-27 19:04
[45063] Re: PC-E Micro NIKKOR 45mm f/2.8D ED
頭配有一個傾斜/移軸機械裝置,確保了攝影者靈活地操控影像透視、變形和對焦。
該鏡頭使用一個特殊的接口,為透視控制提供了 ±11.5 mm 的移軸和 ±8.5°的傾斜。
根據鏡頭標明的1mm或1°刻度間距,移軸和傾斜可通過鏡頭旁的旋鈕方便地進行調節。這款鏡頭光學上可向左或向右旋轉90°,用於透視控制調整,並且每旋轉30°會有一個停頓的提示。
ED鏡片使用。
納米結晶鍍膜。
鏡頭結構(組/片) 8/9
最近主體對焦距離 0.253m
濾鏡接口大小 77mm
遮光罩 HB-43
直徑 x 長度 82.5 x 112mm
重量(大約) 740g
發表時間: 2008-06-29 13:42
[45104] Re: PC-E Micro NIKKOR 45mm f/2.8D ED
不知道Nikon的新PC-E鏡頭,可不可以像Canon的TS-E一樣,很輕易的就可以自行改為擺頭和移軸為同方向
發表時間: 2008-07-01 08:48
[45194] Re: PC-E Micro NIKKOR 45mm f/2.8D ED
法國 focus-numerique.com ,2000 歐元
http://www.focus-numerique.com/news_id-861.html
發表時間: 2008-07-02 06:31
[45270] Re: PC-E Micro NIKKOR 45mm f/2.8D ED
可傾斜/移軸鏡頭
Nikon日本地區發表
http://www.nikon.co.jp/main/jpn/whatsnew/2008/0701_pce45_02.htm
產品介紹
http://www.nikon-image.com/jpn/products/lens/mf/singlefocal/normal/pc-e_45mmf28d_ed.htm
商品名 PC-E Micro NIKKOR 45mm F2.8D ED
日本地區
建議售價300,000日元(含稅 315,000日元)
發售預定日2008年7月18日
焦距: 45mm
最大光圈: F2.8
最小光圈: F32
鏡片構成:8群9枚(包含ED鏡頭1枚)
視角: 51度(最大位軸時,最大值視角66度)
最短攝影距離: 0.253 m
最大攝影倍率:1/2
光圈葉片數: 9枚(圓形光圈)
濾鏡尺寸: 77mm
尺寸: 約82.5 mm×112 mm
重量:約740 g
附件: 77mm鏡頭前蓋 LC-77,鏡頭後蓋 LF-1,遮光罩 HB-43,soft case CL-1120
