 訪客: 347
center   討論區主頁 » NIKON SLR » 傳說的D700是真的無發表權
發表時間: 2008-06-22 08:13
[44728] 傳說的D700是真的
asia.cnet.com
http://asia.cnet.com/2008/06/19/nikon-s-mid-range-full-frame-dslr/?scid=rss_c_crv
CNET Asia就D700的傳聞直接向日本Nikon確認。
雖沒有得到明確的回答,
但Nikon表示等時間到了自然會說,
且承認之前網上流傳的間諜照是從印刷廠流出的。
<參考>
Nikon 新產品傳聞--2008
http://photofan.jp/camera/html/modules/newbb/viewtopic.php?topic_id=4912&forum=5&viewmode=flat&order=ASC&start=20
[44484]起
[44489]
間諜照傳聞源頭(已被刪除)
http://forum.xitek.com/showthread.php?threadid=535009
[44541]
forums傳聞??
http://forums.dpreview.com/forums/read.asp?forum=1021&message=28334834
7月1日2機種發表,
1台是D80後繼機、
另1台是135機 (D3X 或 D700?)
45mm F2.8及85mm F2.8 2隻移軸鏡也同時發表。
另一個傳聞
http://www.northlight-images.co.uk/cameras/Canon_5d2_3d_7d.html
D700
The price is supposed to be ~$3000
* Sensor: 12.1MP CMOS (as per D3) 14-bit linear ADC, 16-bit data pipelines
* Resolution: 12.1MP in FX, 5MP in DX
* Format: FX and DX
* Frame Rate: 5 FPS; up to 6.5 FPS in cropped DX mode.
* Rear LCD: 3"
* Storage: Single CF card
* Grip: MB-D10
http://www.photographybay.com/2008/06/18/nikon-d700/
new Nikon D700:
* FX Format
* 12.1 Megapixel CMOS Sensor
* EXPEED Image Processor
* 14 bit A/D Conversin
* 16 bit Image Processing
* Magnesium Alloy Body
* Compatible with MB-D10 Battery Grip
Nikon D700 Full Specs
Price (body only):
* US $ 2999
Sensor:
* 36 x 23.9 mm CMOS sensor
* FX format
* RGB Color Filter Array
* Built-in fixed low-pass filter
* 12.9 million total pixels
* 12.1 million effective pixels
* 3:2 aspect ratio
Image processor:
* Nikon EXPEED
A/D conversion:
* 14 bit
Image sizes:
(FX format)
* 4256 x 2832 [L; 12.1 MP]
* 3184 x 2120 [M; 6.8 MP]
* 2128 x 1416 [S; 3.0 MP]
(DX format)
* 2784 x 1848 [L; 5.1 MP]
* 2080 x 1384 [M; 2.9 MP]
* 1392 x 920 [S; 1.3 MP]]
File formats:
* NEF (12-bit or 14-bit, compressed or lossless compressed RAW)
* NEF + JPEG
* TIFF
* JPEG (EXIF 2.21)
Lens mount:
* Nikon F mount with AF coupling and AF contacts
* No field of view crop (full-frame)
* When using DX lenses / DX mode 1.5x FOV crop
Usable lenses:
* Type G or D AF NIKKOR: All functions supported
* DX AF NIKKOR: All functions supported except FX-format (36×24)/5:4 (30×24) image size
* AF NIKKOR other than type G or D: All functions supported except 3D Color Matrix Metering II
* AI-P NIKKOR: All functions supported except autofocus and 3D Color Matrix Metering II
* Non-CPU AI NIKKOR: Can be used in exposure modes A and M; electronic rangefinder can be used if maximum aperture is f/5.6 or faster; Color Matrix Metering and aperture value display supported if user provides lens data
Auto Focus:
* 51 focus points (15 cross-type sensors)
* Multi-CAM 3500FX
* AF working range: -1 to +19 EV
* Contrast Detect in Live View (Tripod) mode
Exposure modes:
* Program Auto [P] with flexible program
* Shutter-Priority Auto [S]
* Aperture-Priority Auto [A]
Metering:
* 3D Color Matrix Metering II (type G and D lenses); color matrix metering II (other CPU lenses); color matrix metering (non-CPU lenses if user provides lens data; metering performed)
* Center-weighted: Weight of 75% given to 8, 15, or 20 mm dia. circle in center of frame or weighting based on average of entire frame
* Spot: Meters approx. 4 mm dia. circle (about 1.5% of frame) centered on selected focus point (on center focus point when non-CPU lens is used)
White balance:
* Auto (1005-pixel CCD, image sensor)
* Presets (seven) with fine tuning
* Manual presets (four)
* Color temperature in Kelvin (2500 - 10000 K, 31 steps)
* White balance bracketing (2 to 9 frames, 10,20,30 MIRED steps)
Sensitivity:
* Auto (200 - 6400)
* Up to ISO 25600(expanded range)
Flash Sync Mode:
* Front-curtain Sync (normal)
* Red-Eye Reduction
* Red-Eye Reduction with Slow Sync
* Slow Sync
* Rear-curtain Sync
Storage:
* Compact Flash Type I or II
* UDMA, Microdrive and FAT32 supported
Power:
* Lithium-Ion EN-EL3e (7.4 V, 1500 mAh)
* Included battery charger MH-18a
* Optional AC adapter EH-5a
* Optional MB-D10 battery pack / vertical grip
Vertical grip:
* One Rechargeable Li-ion Battery EN-EL4a, EN-EL4 or EN-EL3e or eight R6/AA-size alkaline (LR6), Ni-MH (HR6), lithium (FR6) batteries, or nickel-manganese ZR6 batteries
kenrockwell.com
http://www.kenrockwell.com/nikon/d700.htm
大圖
http://www.kenrockwell.com/nikon/d700/200_9786-d700-1200.jpg
bfung
發表時間: 2008-06-22 09:26
註冊日: 2006-02-04
發表數: 55
[44730] Re: 傳說D700及2隻移軸鏡頭是真的??
刪除了的資料才是真的。
我估計D700的價錢是(D3+D300)/2,即是D3和D300的中間價。
發表時間: 2008-06-22 09:28
[44731] Re: 傳說D700及2隻移軸鏡頭是真的??
假如Nikon 這台135DSLR 真的取名為D700,
是否意味著Nikon的APS-C DSLR上位機種在D200,D300之後最多只準備出個2、3台
mobile01.com
http://www.mobile01.com/topicdetail.php?f=248&t=668252&last=6741735
介紹的2個D700動畫介紹
http://tw.youtube.com/watch?v=oJvC2HQd22k
http://tw.youtube.com/watch?v=DJn74Rbzujo
meowhoo
發表時間: 2008-06-22 11:44
註冊日: 2006-01-29
發表數: 526
[44735] Re: 傳說D700及2隻移軸鏡頭是真的??
nikon 的命名規則沒什麼規律 只有
個位數 專業機
十位數 消費機
百位數 準專業機
這樣的分別而已
我覺得
D700 上場了就代表 nikon的準專業機不會再出現APS片幅了..
除非40D 的後繼機有很強勢的表現..
D300賣四萬 D700賣八萬 會同時賣一段時間..
D700 賣個兩年後 應該就會出現十位數的FX 機啦
發表時間: 2008-06-22 20:01
[44754] Re: 傳說D700及2隻移軸鏡頭是真的??
我覺得Nikon或其他的厰牌,
按現在的命名方式的話已經(或是遲早將會)到了瓶頸了。
像個位數Pro機,不知在D9之後他們會打算怎麽命名?
還有這次D80的後繼機D90(?)也是已經走到2位數的盡頭了。
反觀Canon的 Mark XX 的命名方式就比較聰明一點。
其實我覺得他們大可以像汽車一樣改型不改名。
BMW的M3永遠都是M3.
victoryuy
發表時間: 2008-06-22 20:13
註冊日: 2006-07-11
發表數: 248
[44755] Re: 傳說D700及2隻移軸鏡頭是真的??
個位數才到D3
D9還遠的勒
就算一代3年
還有18年才用完~~~
實際上一定更久 到時候DSLR這種東西還在不在都不知道
中階就比較讓人擔心...
或許改成兩個英文字配數字?
DX1?
發表時間: 2008-06-22 21:37
[44758] Re: 傳說D700及2隻移軸鏡頭是真的??
命名的問題
根本不用替廠商擔心
基本上只要簡單好記
叫什麼名稱都不是大問題
現在的Dxx.Dxxx等代號可能還沒用完前
應該就會改成新的系列代號了
過去NIKON消費型數位相機不都是3位或4位數字
如今早已改朝換代了
jasonlu
發表時間: 2008-06-23 00:55
註冊日: 2006-08-08
發表數: 11
[44763] Re: 傳說D700及2隻移軸鏡頭是真的??
PENTAKON 寫道:
我覺得Nikon或其他的厰牌,
BMW的M3永遠都是M3.
那這樣不就要像CANON一樣,頂級機永遠是1,然後再來個V、D、DS,不夠用再來MARK I、II、III的?
發表時間: 2008-06-25 18:04
[44932] Re: 傳說D700及2隻移軸鏡頭是真的??
彼岸evolife.cn傳聞
http://www.evolife.cn/?p=4854
發表時間: 2008-06-25 20:52
[44939] Re: 傳說D700及2隻移軸鏡頭是真的??
哇。
真的捏。
頭頂部的曲缐滿好看的。
bfung
發表時間: 2008-06-25 21:42
註冊日: 2006-02-04
發表數: 55
[44941] Re: 傳說D700及2隻移軸鏡頭是真的??
機身左邊的轉盤有銀色圈,D3是沒有的。
相機帶是繡上D700的。
meowhoo
發表時間: 2008-06-25 21:57
註冊日: 2006-01-29
發表數: 526
[44942] Re: 傳說D700及2隻移軸鏡頭是真的??
奇怪的是 好像沒有FX 標誌..
詭異
發表時間: 2008-06-26 06:08
[44964] Re: 傳說D700及2隻移軸鏡頭是真的??
彼岸evolife.cn傳聞
http://forums.dpreview.com/forums/read.asp?forum=1039&message=28403827
刊登的與D300外觀比較圖
發表時間: 2008-06-26 06:10
[44965] Re: 傳說D700及2隻移軸鏡頭是真的??
nikonwatch.com
刊登的傳聞
http://www.nikonwatch.com/?p=520
法國的相機店老板,被邀請6/30-7/1Nikon的新產品內部展覽會。
預料有D700/ D3X / SB-900 的展示。
Alsene845
發表時間: 2008-06-26 07:27
來自: 台灣唯一的隕石湖
發表數: 518
[44970] Re: 傳說D700及2隻移軸鏡頭是真的??
看起來艦橋部大了不少,135片幅+內閃也許有機會喔。
而且說真的,個人覺得這個艦橋部的外型比D3及D300都要好看。
發表時間: 2008-06-26 08:37
[44976] Re: 傳說D700及2隻移軸鏡頭是真的??
D2x與D200有許多共用零件,
D3與D300好像使用了更多的共用零組件來降低成本。
D700也許就是D3與D300零組件的組合變一下就成了D700
最近各大廠為降低成本,
好像都流行這種零組件的組合變一變就可當不同等級的新產品推出
發表時間: 2008-06-26 11:04
[44981] Re: 傳說D700及2隻移軸鏡頭是真的??
小弟的公司最怕聽到的兩句話中的一句就是,
客戶又要要求COST DOWN.
另一句是供應商又要COST UP.
發表時間: 2008-06-26 12:36
[44990] Re: 傳說D700及2隻移軸鏡頭是真的??
雖然D700的傳聞可能要到7/1日才能證明是真是假,
但根據之前
Nikon日本國內SLR組裝工廠年內生產能力將增強3-4倍
http://photofan.jp/camera/html/modules/newbb/viewtopic.php?viewmode=flat&topic_id=4905&forum=35
Nikon社長表示賺錢比市場佔有率更要緊--DSLR將致力於高級機種的市場
http://photofan.jp/camera/html/modules/newbb/viewtopic.php?viewmode=flat&topic_id=5067&forum=35
這兩個新聞推測,
年底前D3的高畫素版外一定還會有較高級機種推出(即使不叫D700也應該是類似機種)。
假如只是D3的高畫素版,
日本國內SLR組裝工廠根本不需要提高到3-4倍產能。
也許這1,2年�堙A高階的135 DSLR會在日本生產,
泰國工廠則負責中、入門的 APS-C機種的生產
發表時間: 2008-06-26 14:23
[44996] Re: 傳說D700及2隻移軸鏡頭是真的??
發表時間: 2008-06-26 23:12
[45021] Re: 傳說的D700是真的??
kakaku.com
傳聞
http://bbs.kakaku.com/bbs/00490711094/SortID=7988789/
[7993648]發言
上週聽到原廠的人隨口說了
「在本月底∼下月中之間發表···」
「(市場)對較容易入手的135相機的迫切期望···」
(1) 2 3 4 ... 12 »
