SONY NEX
SONY A7 II | 無發表權 |
| ADI | 發表時間: 2014-11-20 12:27 |
[101988]
SONY A7 II SONY A7 II
http://www.sonyalpharumors.com/ A7II specs (translated via google): - 24.3 million pixels FF sensor - 5-axis in body stabilization (same as the Olympus E-M1) - LCD monitor 3.0-inch 1.23 million dot. 107 degrees up, and tilt 41 degrees below - EVF 0.5-inch 2.36 million dot - ISO100-25600 (extended with ISO50). Video ISO200-25600 - The shutter speed is 30 seconds -1/8000 seconds - 270 sheets at the number of possible shots EVF use. LCD monitor when using 350 sheets - Continuous shooting 2.5 frames / sec. When speed priority continuous shooting 5 frames / sec. - Video XAVC S, AVCHD, MP4 - The battery is NP-FW50 - The size of 126.9mm x 95.7mm x 59.7mm - Weight 599g (including battery and memory) - Vertical position grip VG-C2EM (sold separately) - Media Memory Stick PRO Duo / PRO-HG Duo / XC-HG Duo, SD / SDHC / SDXC (UHS-I compatible) |
| thundersha | 發表時間: 2014-11-20 13:58 |
[101992]
Re: SONY A7 II 五軸防手震
不曉得耐候性能有無補強,真期待 |
| aztec1234 | 發表時間: 2014-11-20 15:09 |
Quite a regular ![]() ![]() 註冊日: 2012-02-19 來自: 發表數: 55
[101993]
Re: SONY A7 II
| eray | 發表時間: 2014-11-20 15:50 |
Not too shy to talk ![]() ![]() 註冊日: 2006-04-27 來自: Kaohsiung 發表數: 22
[101994]
Re: SONY A7 II
| Pussycat | 發表時間: 2014-11-20 16:30 |
[101995]
Re: SONY A7 II 和Olympus換來的五軸IS終於實裝了
不過竟然可以和鏡頭OSS協同作戰真是很有趣, 不愧是Sony |
| sean | 發表時間: 2014-11-20 17:01 |
[101996]
Re: SONY A7 II
| ADI | 發表時間: 2014-11-20 20:17 |
[101998]
Re: SONY A7 II 當sony的經銷商真的好可憐..... |
| Number5 | 發表時間: 2014-11-20 22:48 |
[102000]
Re: SONY A7 II >>Media Memory Stick PRO Duo / PRO-HG Duo / XC-HG Duo
蛤,這玩意還活著? |
| sean | 發表時間: 2014-12-03 16:29 |
[102072]
Re: SONY A7 II 台灣方面,會在 12 月 6 日直接開賣。Sony A7 II 的淨機身售價為 NT$54,980;連 SEL2870 鏡頭套裝為 NT$62,980。
http://chinese.engadget.com/2014/12/03/sony-a7-ii-hk-tw-price/ |
| Pussycat | 發表時間: 2014-12-03 19:05 |
[102074]
Re: SONY A7 II EOSHD有錄影部分的review了, 五軸防手震可用, S-log也在, 但看來畫質部分Sony還是留一手
http://www.eoshd.com/2014/11/sony-a7-ii-review-5-axis-stabilisation-video-mode/ |
| aztec1234 | 發表時間: 2014-12-04 08:11 |
[102079]
Re: SONY A7 II EOSHD針對錄影時的5軸防震是這麼說的: "The 5 axis stabilisation system is also somewhat underwhelming. I didn’t find it as effective for video as the system Olympus employ in their OM-D E-M1. Handheld pans and tilts are not so much the issue, it is the lack of damping on very high frequency jitter. Granted it was a very cold day and my hand was a little shakier than it normally is! But the difference is obvious. Sony seem to have their own system and it just doesn’t work as well as the one in the E-M1 for video." 簡單來說的話就是...有用,但不像E-M1那麼好, 他認為Sony可能真的是用他們自己的系統而不是拿Olympus的來用 不過我認為也許是FF沒辦法像4/3有比較大的偏移校正空間,不見得是防震系統的問題 至於錄影的畫質...與其說留一手,感覺更像是倉促上架很多問題來不及處理 |
| Zephyr | 發表時間: 2014-12-04 12:51 |
[102084]
Re: SONY A7 II 錄影的話不是由 A7S 主打嗎 ?
| shamicaho | 發表時間: 2014-12-17 10:22 |
[102141]
Re: SONY A7 II 請問 A7 II 喀嚓喀嚓的聲音有改善嗎?
當初 A7 出來時去漢口街試摸,小驚了一下,那聲音總讓人聯想到路易十六被喀嚓時的機械裝置。 |
| ADI | 發表時間: 2014-12-17 12:22 |
[102142]
Re: SONY A7 II 引文:
這個視頻可以解答 https://www.youtube.com/watch?v=G5ADcmaRF-Y 看起來是比A7S 還好 |
| shamicaho | 發表時間: 2014-12-17 17:01 |
[102144]
Re: SONY A7 II 引文:
問題就出在這裡,根據 street shutter 的文章裡提到 steve 用體積不同的鏡頭來測試是不太公平的,而且畫面沒有一氣呵成會令人懷疑。 Unfortunately I’m not sure this is a fair test of the new camera’s shutter sound. As one commenter pointed out – the Sony A7 II has a large zoom lens on it which may be dampening the sound a bit. You’d really need to test both cameras with the same lens to get an accurate idea of the differences. 而另一段 youtube 影片的比較則差距不大,所以才想問有沒有仁兄親身體驗的感覺。 http://youtu.be/UIEdw8X7aPY 文章出處:http://www.streetshootr.com/sony-a7-ii-shutter-sound-is-pretty-damn-quiet/ |
| ADI | 發表時間: 2014-12-17 17:29 |
[102145]
Re: SONY A7 II 引文:
嗯!~ 那你等我買來開箱再告訴你 不過,我覺得,除非用電子無聲快門,不然機械快門聲音再小你都覺得他很響亮.... 只是路易16被喀嚓跟太監李蓮英被喀嚓 的差別而已,都是頭,而且都很痛!~ |
| shamicaho | 發表時間: 2014-12-17 20:58 |
[102149]
Re: SONY A7 II 引文:
嗯!~ 您講得頭頭是道,但,一個有骨頭跟一個連軟骨都算不上的凝膠體的喀嚓聲應該是很不同的。 目前狀況急如星火,您又沒押開箱日期。怕是遠水救不了近火啦!!!!! |
| ADI | 發表時間: 2014-12-22 14:35 |
[102176]
Re: SONY A7 II
| sean | 發表時間: 2015-01-16 17:23 |
[102349]
Re: SONY A7 II 我們也要有系列還沒出現這台啊?
| ADI | 發表時間: 2015-01-16 20:58 |
[102354]
Re: SONY A7 II 引文:
昨天在漢口街差點兒不爭氣的買了......... 但幸好忘記帶錢包... 身上只有幾百元吃飯錢 |
