討論區主頁 » Samsung NX系統 » NX100 ! | 無發表權 |
turtleknig | 發表時間: 2010-09-07 08:26 |
Just can't stay away 註冊日: 2009-03-07 來自: 發表數: 151
[72164]
NX100 ! The camera has not built-in flash -The display is a 921K AMOLED -The new lenses will be the 20-50mm and the 20mm pancake -The 20-50mm f/3.5-5.6 ED has no OIS system -Both lenses do have a new button, iFn button, it is an extension of Fn button on the camera and you can control the features through the focus ring on the lens. -The EVF is optional and just 201K (300×224) with 0.83X magnification -The new external flash is the GN15 -The other device on the National Geographic picture is a GPS receiver and works with google maps -The camera has 2 select dials, one on top and other around 4 way button -The camera has a lot of direct access and controls. -Th the DOF button is on the left side of the body -This are the dimensions 120.5 × 71 × 34.5 mm -282gr -HD 720p with mono audio -The Auto mode ISO is selectable: 1 step (200, 400, 800, 1600) and 1/3 step (125, 160, 200, etc… until 1600) -Manual ISO selectable from 100 to 6400 from http://www.mirrorlessrumors.com/exclusive-on-mirrorlessrumors-the-nx100-specs-and-image/ |
meowhoo | 發表時間: 2010-09-07 09:24 |
Home away from home 註冊日: 2006-01-29 來自: 發表數: 526
[72165]
Re: NX100 ! 20-50 很小顆 但是沒有OIS 有點不行.. 內閃沒意外也是拿掉了.. 重量比GF1, E-PL1 還要輕 跟nex5 差不多重 這台買來給老婆用剛好 畫質如果跟NX10 一樣.. 定價與nex5 相同的話 實在是很強悍 |
corpse | 發表時間: 2010-09-07 10:04 |
Home away from home 註冊日: 2008-02-28 來自: 發表數: 471
[72166]
Re: NX100 ! 35-70的鏡頭很難用耶 -.-
呵呵 |
ADI | 發表時間: 2010-09-07 10:15 |
攝政王(特權份子) 註冊日: 2004-11-20 來自: 豬寮 發表數: 6943
[72167]
Re: NX100 ! 我只對這支鏡頭有興趣
我想試試ED的效果可以好到啥程度 另外,要是這台有LV自動增亮效果 用來轉接應該是不錯的選擇 |
corpse | 發表時間: 2010-09-07 11:49 |
[72170]
Re: NX100 ! 搞錯了 應該是30-75
那就還ok 以前我在AE1上接的就是35-70 真是的 很難用 |
frontier | 發表時間: 2010-09-07 11:52 |
Quite a regular 註冊日: 2005-03-15 來自: 發表數: 56
[72171]
Re: NX100 !
迷路的小狗 | 發表時間: 2010-09-14 12:27 |
Just can't stay away 註冊日: 2009-04-17 來自: 發表數: 249
[72534]
Re: NX100 ! Mirroless Rumors有更清晰的照片流出了
迷路的小狗 | 發表時間: 2010-09-14 14:19 |
[72553]
Re: NX100 !
ITO | 發表時間: 2010-09-14 14:34 |
[72564]
Re: NX100 ! dpreview.com
http://www.dpreview.com/news/1009/10091414samsungnx100.asp Samsung NX100 Preview http://www.dpreview.com/previews/samsungnx100/ |
opass | 發表時間: 2010-09-14 15:03 |
Home away from home 註冊日: 2007-08-28 來自: 發表數: 933
[72572]
Re: NX100 !
opass | 發表時間: 2010-09-14 19:42 |
[72624]
Re: NX100 ! 台灣官網有產品資訊了
http://www.samsung.com/tw/consumer/cameras/cameras/nx-series/EV-NX100ZBABTW/index.idx?pagetype=prd_detail&returnurl= 規格 http://www.samsung.com/tw/consumer/cameras/cameras/nx-series/EV-NX100ZBABTW/index.idx?pagetype=prd_detail&tab=specification ephotozine Samsung NX100 preview http://www.ephotozine.com/article/Samsung-NX100-preview-14597 |
ADI | 發表時間: 2010-09-14 19:45 |
[72625]
Re: NX100 ! 這台我會買!~
meowhoo | 發表時間: 2010-09-14 21:57 |
[72644]
Re: NX100 ! dpreview 拿到20mm f2.8 了耶 超期待! |
opass | 發表時間: 2010-09-14 22:37 |
[72664]
Re: NX100 ! 根據dc watch
サムスン、ミラーレスデジカメ第2弾「NX100」的最後一段 http://dc.watch.impress.co.jp/docs/news/20100914_393757.html 18-200mmの高倍率ズームレンズと60mmのマクロレンズは2011年第1四半期に発売するとした。2011年第2四半期には、さらに、16mm、85mm、16-80mmという3本のレンズも発表予定という。 目前鏡頭群 18-55mm 50-200mm 30mm 20-50mm 20mm 明年前半年還會再推出 60mm微距 18-200mm 16mm 85mm 16-80mm Samsung跟Panasonic一樣放棄發展DSLR系統後 對於無反光鏡系統的研發果然很大刀闊斧 |
raytracer | 發表時間: 2010-09-14 23:14 |
版主 註冊日: 2004-10-26 來自: US 發表數: 1626
[72673]
Re: NX100 ! 這NX100簡直是照著E-P2開發的,為了拼大小,機身沒有防手振,Kit變焦鏡縮成30-70mm f3.5-5.6,搞不懂的是,如果PEN出這類規格的相機可能被批的天翻地覆
到是iFunction是很棒的創意,只是不知道現今電子化的鏡頭對焦環如何有明確的手感? 機身也是另一賣點,對比E-Pl1簡直像上古時代的產品 |
ADI | 發表時間: 2010-09-15 04:41 |
[72696]
Re: NX100 ! 小弟的NX10拍了快上萬張
在小弟的器材裡面,NX10算是拍的相當勤的一台 之前D300拍了快一年才有這樣的張數 相較於其他同規格的相機(可交換鏡頭的EVIL) NX10 V.S NEX-5 NX10贏在鏡頭,原廠鏡頭的品質,NX10比起NEX-5在JPG直出之下真的好很多,立體感十足 NX10的操控性也比NEX系列要好。 NX10 V.S GF 或是 GH系列 NX10贏在片幅,高ISO雖是各擅勝場,但機身大小相仿,APS的片幅畫質的圓潤立體,顯而易見。 |
ducknest | 發表時間: 2010-09-15 08:34 |
Home away from home 註冊日: 2005-07-12 來自: 發表數: 1238
[72703]
Re: NX100 ! 引文:
如果不是轉接問題....單以Evil來說, NX10真的很不錯...加上這台的操控還有熱靴 真的靶Nex比下去 |
ITO | 發表時間: 2010-09-16 21:31 |
[72826]
Re: NX100 !
Ric | 發表時間: 2010-09-17 06:03 |
Home away from home 註冊日: 2006-01-30 來自: 發表數: 632
[72856]
Re: NX100 ! 剛剛看了友站的影片介紹才發現後方操作區凸出一大塊! (驚)
大部份的 NX100 商攝照片都採正面低角度,剛好遮住後方操作區凸起 我誤以為機身上方金屬的厚度就是機身總厚度 |
collective | 發表時間: 2010-09-17 06:25 |
版主 註冊日: 2004-10-18 來自: 柏格方塊 發表數: 13129
[72860]
Re: NX100 ! SAMSUNG,OLYMPUS及Panasonic的無內建EVF機型都太搞笑了吧?
機頂熱靴設計全都一個樣,讓您裝上EVF就不能用外接閃燈 這到底是怎樣的情形啊 |
(1) 2 » |
