 訪客: 251
center   討論區主頁 » M4/3 (Micro Four Thirds System)討論版 » Olympus PEN 鏡頭 轉接鏡頭組 (3CON-P01)無發表權
發表時間: 2011-01-10 15:27
[74601] Olympus PEN 鏡頭 轉接鏡頭組 (3CON-P01)
這次隨E-PL2一起推出的轉接鏡頭三兄弟,在發佈的新聞上沒有詳細的規格,將一些網路上資料整理以便查詢
FCON-P01 魚眼轉接鏡頭 (Fisheye Converter)
規格
Lens Construction
Lens configuration 3 lenses / 3 groups
Lens Combinations
Master lens M.ZUIKO DIGITAL 14-42mm 1:3.5-5.6 II(Focal length set to maximum wide position recommended)
Focal length 10.4 mm (Micro Four Thirds) / 20.8 mm (35mm format)
Angle of view 120 °
Focusing Range Closest focusing distance: 0.19 m
Magnification 0.11 x (Micro Four Thirds) / 0.22 x (35mm format)
Dimensions
Dimensions 62 mm Ø, 38 mm
Weight 112 g
產品包裝
•FCON-P01 Fisheye Converter
•LC-62C Lens Cap
•LR-3 Lens Rear Cap
•Operating Instructions
FCON-P01 魚眼轉接鏡頭
FCON-P01 魚眼轉接鏡頭結構圖
FCON-P01 魚眼轉接鏡頭接上14-42mm II鏡頭
發表時間: 2011-01-10 15:34
[74602] Re: Olympus PEN 鏡頭 轉接鏡頭組 (3CON-P01)
WCON-P01 廣角轉接鏡頭 (Wide Converter)
規格
Lens Construction
Lens configuration 2 lenses / 2 groups
Lens Combinations
Focal length 11 mm (Micro Four Thirds) / 22 mm (35mm format)
Angle of view 89 °
Focusing Range Closest focusing distance: 0.2 m
Magnification 0.1 x (Micro Four Thirds) / 0.2 x (35mm format)
Dimensions
Dimensions 62 mm Ø, 30,5 mm
Weight 85 g
產品包裝
•WCON-P01 Wide Converter
•LC-62C Lens Cap
•LR-3 Lens Rear Cap
WCON-P01 廣角轉接鏡頭
WCON-P01 廣角轉接鏡頭結構圖
WCON-P01 廣角轉接鏡頭接上14-42mm II鏡頭
發表時間: 2011-01-10 15:57
[74603] Re: Olympus PEN 鏡頭 轉接鏡頭組 (3CON-P01)
MCON-P01 微距轉接鏡頭 (Macro Converter)
規格
Lens Construction
Lens configuration 1 lenses / 1 groups
Lens Combinations
Master lens M.ZUIKO DIGITAL 14-42mm 1:3.5-5.6 II(Focal length set to maximum tele position recommended)
Focusing Range 0.24 m - 0.51 m
Magnification 0.28 x (Micro Four Thirds) / 0.56 x (35mm format)
Enclosed macro adapter MA-P01 is required for attaching the MCON-P01
Master lens 2 M.ZUIKO DIGITAL ED 14-150mm 1:4.0-5.6(Focal length set to maximum tele position recommended)
Focusing Range 2 0.35 m - 0.57 m
Magnification 2 0.4 x (Micro Four Thirds) / 0.8 x (35mm format)
Master lens 3 M.ZUIKO DIGITAL ED 40-150mm 1:4.0-5.6(Focal length set to maximum tele position recommended)
Focusing Range 3 0.42 m - 0.57 m
Magnification 3 0.47 x (Micro Four Thirds) / 0.94 x (35mm format)
Dimensions
Dimensions 69 mm Ø, 15 mm
Weight 23 g
產品包裝
•MCON-P01 Macro Converter
•LC-62C Lens Cap
•LR-3 Lens Rear Cap
•MA-P01 Macro Adapter
MCON-P01 微距轉接鏡頭
MCON-P01 微距轉接鏡頭結構圖
MCON-P01 微距轉接鏡頭接上14-42mm II鏡頭
MCON-P01其實只有銀色部分,黑色部分是可拆解的MA-P01 微距轉接環(Macro Adapter),將銀色MCON-P01 58mm接口轉成37mm接口
銀色的MCON-P01與黑色的MA-P01
發表時間: 2014-01-16 09:25
[98527] Re: Olympus PEN 鏡頭 轉接鏡頭組 (3CON-P01)
raytracer 寫道:
規格
Lens Construction
Lens Combinations
Dimensions
Weight 23 g
產品包裝
•LC-62C Lens Cap
•LR-3 Lens Rear Cap
MCON-P01 微距轉接鏡頭
MCON-P01 微距轉接鏡頭結構圖
digicame-info.com傳聞
オリンパスが近日中にED14-42mm F3.5-5.6 EZ と25mm F1.8を発表?
http://digicame-info.com/2014/01/ed14-42mm-f35-56-ez25mm-f18.html
新微距轉接鏡頭 (Macro Converter)
MCON-P02
近日發表
發表時間: 2014-01-29 18:28
[98762] Re: Olympus PEN 鏡頭 轉接鏡頭組 (3CON-P01)
digicame-info.com傳聞
MCON-P02
近日發表
オリンパス、マクロコンバーターレンズをリニューアル
http://dc.watch.impress.co.jp/docs/news/20140129_632193.html
