 訪客: 777
center   討論區主頁 » M4/3 (Micro Four Thirds System)討論版 » Olympus 和 Panasonic 發表 Micro Four Thirds 規格無發表權
發表時間: 2008-08-05 13:05
[46490] Olympus 和 Panasonic 發表 Micro Four Thirds 規格
news
http://www.dpreview.com/news/0808/08080501microfourthirds.asp
支援更短的鏡後距離,
為取消反光鏡鋪路
發表時間: 2008-08-05 13:10
[46491] Re: Olympus / Panasonic announce Micro Four Thirds
While continuing to develop Four Thirds System interchangeable lens type digital camera system products, Panasonic will also develop a new generation of compact, lightweight, interchangeable lens type digital camera system products, including ultra-portable camera bodies, interchangeable lenses, and related system accessories.
我覺得這句話最耐人尋味, 有可能是Panasonic和Leica可能會同時出Digital 4/3 system RF喔!!!
發表時間: 2008-08-05 13:13
[46493] Re: Olympus / Panasonic announce Micro Four Thirds
RF不太可能吧,那麼多變焦鏡
ross_tt
發表時間: 2008-08-05 13:15
註冊日: 2006-06-11
發表數: 146
[46494] Re: Olympus / Panasonic announce Micro Four Thirds
支援更短的鏡後距離,
為取消反光鏡鋪路
既然大家前仆後繼的做 liveview ,乾脆直接生產沒有反光鏡的機身!
正所謂:欲練神功,必先自宮?
發表時間: 2008-08-05 13:17
[46495] Re: Olympus / Panasonic announce Micro Four Thirds
"Lens mount diameter 6 mm smaller (44 versus 50 mm)"
趕快去查查哪種牌子的鏡頭可以接上44mm直徑的??
發表時間: 2008-08-05 13:18
[46496] Re: Olympus / Panasonic announce Micro Four Thirds
發表時間: 2008-08-05 13:19
[46497] Re: Olympus / Panasonic announce Micro Four Thirds
RF不太可能吧,那麼多變焦鏡
沒有反光鏡的相機還能夠叫作SLR嗎? 除了RF以外, 有沒有更好的名字? Video camera 攝影相機???
發表時間: 2008-08-05 13:20
[46498] Re: Olympus / Panasonic announce Micro Four Thirds
monte920 寫道:
轉接環支援的接環要增加了
發表時間: 2008-08-05 13:26
[46501] Re: Olympus / Panasonic announce Micro Four Thirds
看來之前謠傳的Nikon要出APS-C的DC甚至RF的謠言也不是不可能了!!
Alsene845
發表時間: 2008-08-05 13:27
來自: 台灣唯一的隕石湖
發表數: 518
[46503] Re: Olympus / Panasonic announce Micro Four Thirds
* Contrast Detect AF is implied (passive would require an external sensor)
取消反光鏡,所以連帶相位差AF也沒了。看起來是走向compact DC的路子,和原本的4/3系統有明顯區隔。
原來的4/3系統如果再加上之前在傳言的whole frame,上下通吃的意圖明確啊!
* Lens to body electrical contact points up to 11 from 9
有新增什麼功能嗎?
* Lenses of same focal length and maximum aperture considerably smaller than Four Thirds
不懂
* Lack of mirror well necessitate a high quality EVF (or an EVF/Viewfinder-less design)
因為沒有反光鏡,所以沒有OVF了,也不用搞什麼RF了,直接是EFV取景的compact DC了。
發表時間: 2008-08-05 13:28
[46504] Re: Olympus / Panasonic announce Micro Four Thirds
Micro Four Thirds與Four Thirds的主要變更點
1.鏡候距離(mount和感光元件的間隔)的縮短=縮短為「4/3系統規格」的約1/2
2.mount直徑的縮小=「4/3系統規格」,外徑縮小約6mm
3. mount電子接點變更9點→11點
發表時間: 2008-08-05 13:30
[46505] Re: Olympus / Panasonic announce Micro Four Thirds
monte920 寫道:
轉接環支援的接環要增加了
4/3鏡頭可透過轉接環使用,所有轉接到4/3的鏡頭再接此轉接環到 Mrcro Four Thirds
唯一擔心是
想想鏡後距縮短一半,似乎要用矯正鏡片才行
發表時間: 2008-08-05 13:33
[46506] Re: Olympus / Panasonic announce Micro Four Thirds
之前的這個算是試探市場反應
參考
[44978] Re: Olympus有趣的新專利申請(2)----數位版PEN F??
http://photofan.jp/camera/html/modules/newbb/viewtopic.php?topic_id=4187&forum=2&post_id=44978#forumpost44978
forums
網友想像的Pen Digital
http://forums.dpreview.com/forums/read.asp?forum=1022&message=28405354
機身尺寸設定是以想像E-420取掉反光鏡取景器部分後的機身尺寸。
http://i56.photobucket.com/albums/g199/TrevorT001/OlympusPENbody.jpg
http://i56.photobucket.com/albums/g199/TrevorT001/OlympusPENcolors.jpg
http://i56.photobucket.com/albums/g199/TrevorT001/OlympusPENlenses.jpg
連4/3鏡頭轉接環都想到了。
其實以前小弟也曾想過Panasonic該研發類似的系統,
如此與Olympus就能更差別化
發表時間: 2008-08-05 13:34
[46507] Re: Olympus / Panasonic announce Micro Four Thirds
Alsene845 寫道:
不懂
就是說它如果出了一支新的25mm f1.4的鏡頭的話, 會比現有Leica那一支給4/3用的體積小很多的意思.
只是原來的4/3鏡頭接上去我想應該是有焦長的變化囉?
focus
發表時間: 2008-08-05 13:40
註冊日: 2006-10-02
發表數: 10
[46509] Re: Olympus / Panasonic announce Micro Four Thirds
非常創新,又很大膽的設計思維! 非常吸引人!
看來,4/3現在的鏡頭是可以用adapter轉接到[micro 4/3]機身上。不過重要的是adapter要有電子接點,才可以讓現在4/3鏡頭能夠自動對焦。
另外,有adapter轉接4/3鏡頭到[micro 4/3]機身上,這代表手邊的老鏡頭也可以囉~ 嘿嘿嘿~
最後,不知OLYMPUS PEN系列的鏡頭是否有專屬的adapter可轉接到[micro 4/3]。如果可以~ 那真是讓人大流口水了.....
期待!
發表時間: 2008-08-05 13:47
[46510] Re: Olympus / Panasonic announce Micro Four Thirds
raytracer 寫道:
monte920 寫道:
轉接環支援的接環要增加了
唯一擔心是
連Leica M、Olympus pen鏡頭都可能轉接了
Leica M Mount 27.8mm
Olympus Pen F Mount 29.3mm
4/3 Mount 38.58mm/2 約為19.3mm
參考
http://photofan.jp/camera/html/modules/xfsection/article.php?articleid=28
發表時間: 2008-08-05 13:49
[46511] Re: Olympus / Panasonic announce Micro Four Thirds
raytracer 寫道:
monte920 寫道:
轉接環支援的接環要增加了
唯一擔心是
>Flange back distance half that of Four Thirds (20 versus 40 mm)
如果是4/3轉Micro 4/3應該只是加個Extension tube 20mm
發表時間: 2008-08-05 13:51
[46512] Re: Olympus / Panasonic announce Micro Four Thirds
jerloong 寫道:
raytracer 寫道:
monte920 寫道:
轉接環支援的接環要增加了
唯一擔心是
YES! 想太多了
IvanTseng
發表時間: 2008-08-05 13:52
註冊日: 2004-11-24
發表數: 297
[46513] Re: Olympus / Panasonic announce Micro Four Thirds
好個 Olympus 呀... Orz
這算是第一台可以錄影的 DSLR 嘛?
恩, 取消反射鏡了... 也的確不應該叫做 DSLR 哩..
那應該說是第一台可以錄影的可換鏡頭 DC 嘛?
看到這消息還算是挺興奮的...
尤其是可能有新增轉接他場鏡頭的機會...
真的是讓人振奮啊....
lamancha
發表時間: 2008-08-05 13:53
註冊日: 2006-02-26
發表數: 167
[46514] Re: Olympus / Panasonic announce Micro Four Thirds
monte920 寫道:
Alsene845 寫道:
不懂
不會, 焦長的變化(或是倍率轉換)與感光元件的片幅有關, 與鏡後距無關, 換句話說, 25/1.4的鏡頭, 用在4/3系統或是micro 4/3系統上的視角都是一樣的, 只要感光元件的大小一樣的話
鏡後距縮短, 鏡頭的尺寸可以連帶縮小(可以比較看看同樣是50/2的規格, rf鏡頭和slr鏡頭的比較), 但是代價是光錐角變大, 邊緣畫質下降及變角失光的情形會比較嚴重
另外, micro 4/3是較短的鏡後距系統, 所以4/3的鏡頭(鏡後距較長)轉接時只要有轉接環就可以了, 不需要矯正鏡片
(1) 2 3 4 ... 9 »
