 訪客: 214
center   討論區主頁 » M4/3 (Micro Four Thirds System)討論版 » OLYMPUS OM-D E-M1 Mark II 靠韌體進化中無發表權
發表時間: 2017-02-02 23:28
[106999] OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
Olympus interview at Dpreview: “we will be improving the E-M1 Mark II with firmware upgrades”
http://www.43rumors.com/olympus-interview-at-dpreview-we-will-be-improving-the-e-m1-mark-ii-with-firmware-upgrades/
發表時間: 2017-02-03 09:26
[107000] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
硬體進化(過剩??)到某個程度,就可以靠韌體更新一直改善上去......
發表時間: 2017-03-02 11:50
[107408] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
OM-D E-M1 Mark II 最新韌體 Ver.1.1 公開
OM-D E-M1 Mark IIソ最新иャみуヨラヤゎ公開
OLYMPUS Viewer 3パRAW現像画質メ改善
http://dc.watch.impress.co.jp/docs/news/1047256.html
http://cs.olympus-imaging.jp/jp/support/cs/dslr/fw/index.html#omd
發表時間: 2017-03-02 17:59
[107413] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
今天升級韌體才發現USB接線頭換了。
發表時間: 2017-05-07 13:36
[108123] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
傳聞
新韌體
E-M1 Mark II Ver1.2
300mm PRO Ver 1.2
E-M5 Mark II Ver 2.4
明天公開
43rumors.com
(FT5) New E-M1II, E-M5II and 300mm firmwares will be released on Monday (read the improvements list)
http://www.43rumors.com/ft5-new-e-m1ii-and-300mm-firmwares-will-be-released-on-monday-read-the-improvements-list/
E-M1II Version: 1.2
Improved color reproduction of the electronic viewfinder.
The problem that flash devices from other vendors emit no flash during high-resolution exposures / focus stacking / focus stacking has been fixed.
The problem that the back monitor does not display the shooting view when the electronic viewfinder is used to take photos has been fixed.
The problem that the preset position of the AF target is not retained when the unit is turned off has been fixed.
Improved (stability of) capacity indicator of the battery status.
Improved noise reduction of serial shots when the lens is stabilized.
Profoto-manufactured flash controllers are supported.
300mm PRO version: 1.2
Improved noise reduction of serial shots with the image stabilizer on and the use of an E-M1 Mark II.
EM5II Version: 2.4
The camera settings can be saved.
Compensation for medium gradation when using gradation curve correction is possible.
The position of the AF target and the range of spot measurement can be linked.
發表時間: 2017-05-08 14:54
[108135] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
peellden
發表時間: 2017-05-09 22:04
註冊日: 2006-01-10
發表數: 164
[108145] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
更新之後觀景窗的顏色正確多了,不然之前實在是很困擾,看出去整片慘澹陰森,用觀景窗拍照一整天心情都不太好。
發表時間: 2017-06-29 23:25
[108580] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
發表時間: 2017-12-19 17:28
[109235] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
發表時間: 2018-02-20 16:43
[109488] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
E-M1 Mark II韌體 Ver. 2.0 預定28日公開
但有些地區已可下載
You can download the new E-M1II firmware now!
https://www.43rumors.com/can-get-new-e-m1ii-firmware-now/
發表時間: 2018-02-28 13:57
[109633] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
「OM-D E-M1 Mark II」Ver.2.0、「OLYMPUS PEN-F」Ver.3.0
れプヂ「OM-D E-M5 Mark II」Ver.4.0
иャみуヨラヤソヤЧкヲяみЭメ実施
https://www.olympus.co.jp/news/2018/nr00704.html
新韌體
公開
發表時間: 2018-03-01 16:50
[109667] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
иャみуヨラヤソヤЧкヲяみЭメ実施
新韌體
公開
有個新功能,機身內Fisheye補正(8mm F1.8 Fisheye PRO 使用時),
http://digital-faq.olympus.co.jp/faq/public/app/servlet/qadoc?QID=006640
機身內可將魚眼鏡補正為以下廣角
иュЧЁшヤユ補正
On : 1
123°
約 5.5mm相当 (約 11mm相当)
On : 2
114°
約 7mm相当 (約 14mm相当)
On : 3
100°
約 9mm相当 (約 18mm相当)
此功能以前透過 「OLYMPUS Viewer3」可做變換補正
http://thisistanaka.blog66.fc2.com/entry/961/
E-M1 Mark II 可在機身內就做
發表時間: 2018-03-09 14:13
[109731] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
OLYMPUS OM-D E-M1 Mark IIソ最新иャみуヨラヤゎ公開
https://dc.watch.impress.co.jp/docs/news/1110661.html
韌體 Ver 2.1公開
發表時間: 2018-09-04 13:43
[110430] Re: OLYMPUS OM-D E-M1 Mark II 靠韌體進化中
Ver.2.2公開
http://dl01.olympus-imaging.com/ww/ud2/JPN/0001/1250/index22a.html
レэ⑦еЗ「OM-D E-M1 Mark II」ソ最新иャみуヨラヤゎ公開
動作安定性ソ向上スジ
https://dc.watch.impress.co.jp/docs/news/1141379.html
Ver.2.2韌體升級後,全部設定會被reset
