 訪客: 214
center   討論區主頁 » M4/3 (Micro Four Thirds System)討論版 » OLYMPUS M.ZUIKO DIGITAL ED 300mm F4.0 IS PRO 新韌體無發表權
發表時間: 2016-11-22 22:01
[106417] OLYMPUS M.ZUIKO DIGITAL ED 300mm F4.0 IS PRO 新韌體
新韌體公開
M.ZUIKO DIGITAL ED 40-150mm F2.8 PRO Ver.1.2
M.ZUIKO DIGITAL ED 300mm F4.0 IS PRO Ver.1.1
M.ZUIKO DIGITAL ED 8mm F1.8 Fisheye PRO Ver.1.1
http://cs.olympus-imaging.jp/jp/support/cs/dslr/fw/index.html#mzd
發表時間: 2017-05-07 13:38
[108124] Re: OLYMPUS M.ZUIKO DIGITAL ED 300mm F4.0 IS PRO 新韌體
傳聞
新韌體
E-M1 Mark II Ver1.2
300mm PRO Ver 1.2
E-M5 Mark II Ver 2.4
明天公開
43rumors.com
(FT5) New E-M1II, E-M5II and 300mm firmwares will be released on Monday (read the improvements list)
http://www.43rumors.com/ft5-new-e-m1ii-and-300mm-firmwares-will-be-released-on-monday-read-the-improvements-list/
E-M1II Version: 1.2
Improved color reproduction of the electronic viewfinder.
The problem that flash devices from other vendors emit no flash during high-resolution exposures / focus stacking / focus stacking has been fixed.
The problem that the back monitor does not display the shooting view when the electronic viewfinder is used to take photos has been fixed.
The problem that the preset position of the AF target is not retained when the unit is turned off has been fixed.
Improved (stability of) capacity indicator of the battery status.
Improved noise reduction of serial shots when the lens is stabilized.
Profoto-manufactured flash controllers are supported.
300mm PRO version: 1.2
Improved noise reduction of serial shots with the image stabilizer on and the use of an E-M1 Mark II.
EM5II Version: 2.4
The camera settings can be saved.
Compensation for medium gradation when using gradation curve correction is possible.
The position of the AF target and the range of spot measurement can be linked.
發表時間: 2017-05-08 14:46
[108133] Re: OLYMPUS M.ZUIKO DIGITAL ED 300mm F4.0 IS PRO 新韌體
發表時間: 2018-02-28 15:24
[109637] Re: OLYMPUS M.ZUIKO DIGITAL ED 300mm F4.0 IS PRO 新韌體
新韌體公開
ED 300mm F4.0 IS PRO Ver.1.4
ED 12-100mm F4.0 IS PRO Ver. 1.3
M.ZUIKO DIGITAL я⑦И 2機種(ED 300mm F4.0 IS PRO / ED 12-100mm F4.0 IS PRO)иャみуヨラヤヤЧкЫみЬ公開
