 訪客: 181
center   討論區主頁 » M4/3 (Micro Four Thirds System)討論版 » 我們終於也有了之Panasonic LUMIX DMC-GH4開箱無發表權
發表時間: 2014-10-02 11:48
發表數: 13174
[101566] 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
本來說好不跟的,不過最近為了幫GH3買電池跑到相機店訂公司貨電池,才發現GH4跟電池的公司貨竟然比iPhone 6還難買...
有沒有搞錯啊
結果昨天通知有東西進來,竟然只有相機組沒有單賣的電池...阿今罵是啥米狀況咧....可惡,為了電池.....
買了
開箱
GH4本尊及電池及充電器,台松公司貨電池的型號是DMW BLF19GT,竟然掛"GT"耶!很會跑嗎
發表時間: 2014-10-02 17:43
[101570] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
發表時間: 2014-10-02 20:02
[101571] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
Release note:
Ver 2.0
[4K PHOTO] mode is added which records 4K video exclusively for capturing a frame to save as a photo.
Settings can be adjusted as below when entering this mode.
- Rec Format : MP4
- Rec Quality : 4K 30p, 100Mbps (System Frequency 59.94Hz) ,
4K 25p, 100Mbps (System Frequency 50.00Hz)
- Luminance Level:0-255
In addition to 16:9 aspect, 4:3 / 3:2 / 1:1 can be selected.
Exif information is embedded to the captured image from the 4K video.
Marking function is available enables marker setting on the designated point while recording video and users can jump to the markers when playing back the video to capture the frame they want.
Loop Recording function is added, with which the camera keeps on recording video while deleting the old footage automatically.
4K 23.98p, 100Mbps mode is added in MP4 video recording.
The upper limit of the ISO sensitivity can be set in the menu of ISO sensitivity setting and emission amount of flash light can be adjusted in the menu of exposure compensation.
Focusing performance of 1-area AF in video recording is improved.
Tracking performance of tracking AF when used with the interchangeable lens H-FS14140 is improved.
Remote shooting via USB tethering is available by using PC software "USB Tether" supplied by Promote Systems.
蠻好奇這段怎麼做? 錄影中可以拍照還是影片可以by frame記錄EXIF做事後輸出?
發表時間: 2014-10-02 23:00
發表數: 13174
[101572] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
小弟剛入手的GH4,韌體還是1.1版的.
發表時間: 2014-10-02 23:13
[101573] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
嘖嘖嘖!~ 這一台四萬多你也買得下手
還買公司貨........你不知道台灣PANASONIC敢修冰箱也敢修相機嗎??
發表時間: 2014-10-03 00:11
[101574] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
Collective 大好樣的,每役必與。
最近才有人在說 GH 系列是唯一型號還連續的產品
Collective 大可以排出 GH1 到 GH4 的「順子」真是不容易
如果排出 GH 疊疊樂應該很難遇到敵手吧
發表時間: 2014-10-03 06:50
發表數: 13174
[101576] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
嘖嘖嘖!~ 這一台四萬多你也買得下手
啟稟大王,這次GH4公/水價格非常接近,所以就支持一下囉
臺灣松下敢修冰箱也敢修相機我知道啊,除此之外東西還很多咧...
不過話說回來日本松下也是包山包海啊,還有腳踏車哩.在大阪附近地區就能感受到松下的無所不在.
發表時間: 2014-10-03 06:57
發表數: 13174
[101577] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
kkao兄,
小弟太敗家了
跟我同時間買GH1的同事都還在用,沒想到一晃眼就來到GH4了.
有時同事會拿相機來問我一些拍攝上的問題,這才驚覺真的差很多.通常最後我都會請他趕快升級相機做為總結
發表時間: 2014-10-05 23:01
發表數: 1917
[101590] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
我看到網路上提到GH4的DFD對焦比EM-1的混合對焦還猛.....快去安排測試一下啦~~~
搞不好GH4轉接ZD 300/2.8也很猛.......
LUMIX GH4の「空間認識AF」は何が凄い?
http://dc.watch.impress.co.jp/docs/news/interview/20140530_649605.html
發表時間: 2014-10-06 00:13
發表數: 13174
[101592] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
Number5 寫道:
Number5兄,
收到.
我相信GH4接M4/3鏡頭有蠻大機會比E-M1強.我會去做測試再回來報告
不過,剛剛把ZD328轉接到GH4上試了一下,結果是"悲劇"
土香
發表時間: 2014-10-06 10:17
註冊日: 2010-02-07
發表數: 256
[101593] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
之前朋友借我ZD 150/2鏡頭接在 Panasonic GH2 上也是水土不服
但是L10的14-50 接在Panasonic GH2 就頭好壯壯
他們2家真的不好溝通
不過M4/3我已經全部退出了.
發表時間: 2014-10-06 13:02
發表數: 13174
[101594] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
土香 寫道:
...恕刪
不過M4/3我已經全部退出了.
好可惜...那篇"用100-300來拍鳥"就這樣沉了
土香
發表時間: 2014-10-07 16:49
註冊日: 2010-02-07
發表數: 256
[101604] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
那也是沒辦法啦!
機子不便宜,鏡頭焦段又不夠長.
不過那些日子也是值得回味啦!!
土香 寫道:
...恕刪
不過M4/3我已經全部退出了.
發表時間: 2014-10-11 21:33
發表數: 13174
[101638] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
相機:Panasonic LUMIX DMC-GH4
ISO 800
拍攝快門: 1/40s
鏡頭: Panasonic LEICA DG 42.5mm F1.2 ASPH.
拍攝光圈: f/5.6
RW2檔,SILKYPIX D.S.5.0Pro解出,ACDsee縮圖銳化
ISO ˋ4000
拍攝快門: 1/400s
拍攝光圈: f/2.0
發表時間: 2014-10-12 14:46
發表數: 13174
[101641] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
GH4的對焦韌體很不錯,確實是又快又準.不過也有罩門,個人發現兩個,其一是當碰上強的直射光源時,GH4的對比對焦就會一直脫焦讓點光源呈現散景圓餅狀,無法正確合焦.這點小弟是在台北火車站台鐵地下月台要拍攝即將離站的太魯閣號的車尾時發現的.起初還以為是鏡頭壞了後來在等車的時候又意外發現將對焦點指向軌道旁的號誌燈,在號誌燈光線近乎直射進入鏡頭時也發生同樣的問題.經過反覆試驗後確認了這個"特性".隔天我帶了E-M1跟同一支鏡頭去試,相同的場景就完全OK.
其二是拍攝特定更新率的螢幕時會發生無法合焦的情形,此時透過EVF所見螢幕亦是非常奇怪的影像,我猜是相機的更新率與螢幕更新率的問題,不過小弟目前還沒找到可以避免的設定.
相較於GH3,GH4的對焦已改成AFS/AFF(繁體中文版機身上的註解為"靈活的AF"),不再是AFC了.
另外跟GX7相同,觸控板AF的選項裡有EXACT跟OFFSET的選項.其中OFFSET的選項可以讓習慣於使用EVF的用家可以在機背螢幕上先粗略的點選合焦點,然後再使用EVF取景拍攝時再利用左手拇指操作,不必點到畫面上正確對焦點的位置而是用拖動的方式去再次修正對焦點至理想的位置,非常好用!
發表時間: 2014-10-22 14:37
發表數: 13174
[101741] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
更正,GH4仍然有獨立AFC檔位,另切換至AFS/AFF檔位可由選單選擇AFS或AFF模式
以下照片是GH4+M.ZD 12-40mm F2.8 PRO拍攝,拍攝焦段為12mm,RW2檔以SILKYPIX D.S. 5.0局部裁切解出,ACDsee縮圖銳化.
拍攝光圈為f/6.3,ISO200,快門1/800s.
拍攝時刻為上午十一點半左右拍攝由臺東北上,剛通過山里車站不久,準備駛上鹿野溪橋的普悠瑪自強號列車.當時的天氣為晴時多雲,拍攝當下白雲遮住了日光.
雖是局部裁切的照片,但是鐵道兩旁駁坎上方植被的樹葉層次分明,我很滿意
也因為GH4的設計與高性能,讓我能在剛就拍攝位置就聽見火車來了時能迅速反應以單手伸展高舉握持相機越過台鐵的保安設施以直幅構圖方式,右手食指第二節按快門的方式拍攝.
發表時間: 2014-12-20 21:51
發表數: 13174
[102159] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
先前小弟入手時大王還在虧小弟,沒想到今天大王竟然轉性說會考慮買台GH4當工作機!
期待吾王開箱
發表時間: 2014-12-20 22:18
[102160] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
期待吾王開箱
那 E-M1賣你 ??
滿手M43機身,我才沒那麼笨
下次要開SONY A7 II 啦!!
發表時間: 2014-12-20 22:53
發表數: 13174
[102162] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
那 E-M1賣你 ??
滿手M43機身,我才沒那麼笨
下次要開SONY A7 II 啦!!
是小弟笨.
GH1/2/3/4
G2
GF3
GX7
E-M1
真是笨
發表時間: 2014-12-21 06:36
[102164] Re: 我們終於也有了之Panasonic LUMIX DMC-GH4開箱
是小弟笨.
GH1/2/3/4
G2
GF3
GX7
E-M1
真是笨
你不是笨,你是執著
同樣的東西,買那麼多幹嘛??
也讓別人有機會買到嘛!!
更何況,我防潮箱也放不下啊!!
