°Q½×°Ï¥D¶ » RICOH » RICOH¡uGR DIGITAL II¡v¥\¯àÂX±i¶´Åé09¦~8¤ë5¤é¤½¶} | µLµoªíÅv |
¾ðª¬Åã¥Ü | ·sªº¦b«e | «e¤@Ó¥DÃD | ¤U¤@Ó¥DÃD | ¶§À |
µoªíªÌ | °Q½×¤º®e |
wkho9296 | µoªí®É¶¡: 2009-07-27 14:35 |
Not too shy to talk µù¥U¤é: 2007-08-09 ¨Ó¦Û: µoªí¼Æ: 11
[62013]
wkho9296 | µoªí®É¶¡: 2009-08-04 09:59 |
[62322]
Re: RICOH¡uGR DIGITAL II¡v¥\¯àÂX±i¶´Åé09¦~8¤ë5¤é¤½¶} <Enhanced functions>
(1) Displayed-file memory in playback mode For playback, the file displayed is the last file that was displayed the last time playback mode was used. (In cases where photographs have been taken, the most recently taken photograph is displayed.) (2) One press zoom with ADJ. lever When displaying still images in playback, pressing the ADJ. lever will display the image magnified. (3) One press zoom ratio selection The zoom ratio can be selected for use for one press zoom in playback. (4) Playback mode dial option selection In addition to the following combination "ADJ. lever: Next/previous frame; Up-down dial: Zoom in/out," it is now possible to select this combination: "ADJ. lever: Scroll left/right; Up-down dial: Scroll up/down" (5) Changing dial functions for manual exposure mode It is possible to change the dial functions so that the ADJ. lever controls aperture and the up-down dial controls shutter speed. (The normal setting is the reverse.) |
wkho9296 | µoªí®É¶¡: 2009-08-05 10:35 |
[62376]
ITO | µoªí®É¶¡: 2009-08-05 10:38 |
ºô¯¸ºÞ²zû µù¥U¤é: 2004-09-15 ¨Ó¦Û: ¤é¥» µoªí¼Æ: 30762
[62378]
Re: RICOH¡uGR DIGITAL II¡v¥\¯àÂX±i¶´Åé09¦~8¤ë5¤é¤½¶} ·PÁÂwkho9296¥Sªº¸ê°T¤À¨É
wkho9296 | µoªí®É¶¡: 2009-08-05 21:08 |
[62407]
Re: RICOH¡uGR DIGITAL II¡v¥\¯àÂX±i¶´Åé09¦~8¤ë5¤é¤½¶} ^¤åª©¡G
http://www.ricoh.com/r_dc/download/firmware/grd2/ §ó·s¤º®e¦p¤U 1)ÀɮצA¥Í®É,Åã¥Ü¤§«eÂsÄý®Éªº³Ì«áÅã¥ÜªºÀÉ®× 2)¦A¥Í®É,«ö¤UADJ±±±ì,¥i©ñ¤j·Ó¤ù 3)¥HADJ±±±ìÂX¤j·Ó¤ùÅã¥Ü®É,¥i¿ï¾Ü©ñ¤j¿²v 4)¤â°ÊÃn¥ú¼Ò¦¡(M¼Ò¦¡)®É,¥i³]©w¬°¥HADJ±ì±±¨î¥ú°é,¤W¤UÁa±ì±±¨î§Öªù³t«× ¦¹¥~,¦A¥Í®ÉªºADJ±±±ì»P¤W¤U±±±ì¥i¿ï¾Ü¨ä¾Þ§@²Õ¦X,¨ãÅé¨Ó»¡... ¡uÂX¤j¬Û¤ùÂsÄý¡v(ADJ)»P¡u©ñ¤j¿²vÅܧó¡v(¤W¤U±±±ì)ªº²Õ¦X¤è¦¡,¥H¤Î ¡uÂX¤j®Éªº¦ì¸m¥ª¥k²¾°Ê¡v(ADJ)©M¡uÂX¤j®Éªº¦ì¸m¤W¤U²¾°Ê¡v(¤W¤U±±±ì)ªº²Õ¦X |
¾ðª¬Åã¥Ü | ·sªº¦b«e | «e¤@Ó¥DÃD | ¤U¤@Ó¥DÃD | ¶º |
µLµoªíÅv | |
