SLR綜合及副廠鏡版
Tamron 60mm F/2 Di II (Model G005) | 無發表權 |
| simon1101 | 發表時間: 2009-03-24 19:10 |
Quite a regular ![]() ![]() 註冊日: 2006-02-02 來自: 發表數: 111
[55829]
Tamron 60mm F/2 Di II (Model G005) http://www.tamron.co.jp/en/news/release_2009/0324.html
![]() Model Name: G005 Focal Length: 60mm Maximum Aperture: F/2.0 Angle of View (diagonal): 26 degrees and 35 minutes (APS-C size equivalent) Optical Construction: 14 elements in 10 groups Minimum Focusing Distance: 0.23m (9.1in.) Max. Magnification Ratio: 1 : 1 Minimum Working Distance: 100mm (3.94in.) Filter Diameter: 55mm Overall Length: 80mm (3.15in.)* Maximum Diameter: 73mm (2.9in.) Weight: 400g (14.1oz.)* Diaphragm Blade Number: 7 Minimum Aperture: F/22 Standard Accessory: Lens Food Compatible Mount: For Canon, Nikon (with built-in AF motor) and Sony |
| opass | 發表時間: 2009-03-24 19:44 |
[55832]
Re: Tamron 60mm F/2 Di II (Model G005) 90mm macro的APS-C版本嗎
不知道會不會再次成為新一代"傳說中的微距鏡頭" |
| Pussycat | 發表時間: 2009-03-24 20:26 |
[55833]
Re: Tamron 60mm F/2 Di II (Model G005) 這規格可以打到Nikon 60mm F2.8 macro, 當人像鏡也不錯
(不過光圈是七片...) |
| Rexlaser | 發表時間: 2009-03-24 21:36 |
Just can't stay away ![]() ![]() 註冊日: 2005-12-29 來自: 伊謝爾倫 發表數: 228
[55838]
Re: Tamron 60mm F/2 Di II (Model G005) Full-time manual control mechanism
Delicate focusing control is essential in macro photography. The lens incorporates a full-time manual control mechanism that enables the user to manually adjust focus without engaging the AF/MF switch-over button, even when in the auto-focus mode. In addition, the lens employs a large focus control ring to ensure a solid grip and precise control when manually focusing. 支援全時手動 Sounds good |
| pho龜oer | 發表時間: 2009-03-25 01:20 |
Not too shy to talk ![]() ![]() 註冊日: 2007-08-22 來自: 發表數: 39
[55844]
Re: Tamron 60mm F/2 Di II (Model G005) 借版問一下,為什麼有些新聞資訊有在討論區�堙A而在新聞區塊�塈鉹ㄗ鴐蛫奰釭熒s聞?
比如這篇。 |
| ITO | 發表時間: 2009-03-25 04:33 |
[55846]
Re: Tamron 60mm F/2 Di II (Model G005) 引文:
因為新聞區塊人手不夠 只有小弟一人兼任新聞播報, 有時間時會發新聞,但沒時間時就無法在新聞區做整理報導了 |
| collective | 發表時間: 2009-03-25 06:24 |
[55847]
Re: Tamron 60mm F/2 Di II (Model G005) 不知道Tarmon有沒有可能發行這一管的4/3接環版本
真有的話,那就太棒了 |
| corpse | 發表時間: 2009-03-25 07:15 |
[55851]
對啊 好期待可以用在43系統 TAMRON沒支援過43系統是嗎? .......唉 我覺得APS的副場鏡裝在43系統是滿恰當且經濟的選擇 |
| ITO | 發表時間: 2009-03-27 21:00 |
[56004]
Re: Tamron 60mm F/2 Di II (Model G005) SP AF60mm F/2 Di II Macro 1:1 (Model G005) 開發
http://www.tamron.co.jp/news/release_2009/0324.html 號稱是世界初APS-C DSLR用 F2大口徑 Macro鏡頭 日本dc.watch 【PIE2009】タムロン、「SP AF 60mm F2 Macro 1:1」を参考出品 http://dc.watch.impress.co.jp/cda/other/2009/03/27/10551.html |
| ITO | 發表時間: 2009-06-16 23:41 |
[60066]
Re: Tamron 60mm F/2 Di II (Model G005) tamron.co.jp
『SP AF60mm F/2 Di II MACRO 1:1(Model G005)』 Canon用 日本地區上市日及價格發表 http://www.tamron.co.jp/news/release_2009/0616.html 日本地區上市日:2009年6月25日 日本地區建議零售價:71,000日圓 |
| ITO | 發表時間: 2009-07-27 20:20 |
[62024]
『SP AF60mm F/2 Di II MACRO 1:1(Model G005NII)』 Nikon用 (搭載AF馬達) 日本地區上市日發表 http://www.tamron.co.jp/news/release_2009/0727.html 日本地區上市日2009年7月30日 |
| Pussycat | 發表時間: 2009-07-29 00:31 |
[62053]
| ITO | 發表時間: 2009-07-29 07:28 |
[62058]
http://www.tamron.co.jp/news/release_2009/0728.html 『SP AF60mm F/2 Di II MACRO 1:1(Model G005NII)』 Nikon用 (搭載AF馬達) 日本地區上市日變更: 變更前上市日 2009年7月30日 變更後上市日 2009年8月20日 |
| ITO | 發表時間: 2009-09-29 10:04 |
[64282]
Re: Tamron 60mm F/2 Di II (Model G005) SP AF60mm F/2 Di II MACRO 1:1(Model G005) SONY用發表 http://www.tamron.co.jp/news/release_2009/0928.html 日本地區上市日2009年10月1日 |
(不過光圈是七片...)
