 訪客: 87
center   討論區主頁 » Four Thirds System and Olympus SLR » Olympus 關於模組化相機的專利無發表權
發表時間: 2010-07-16 23:06
[71187] Olympus 關於模組化相機的專利
日本專利局最近公開的
Olympus 關於模組化相機的專利
雖看不太懂全部內容,但重點好像是在轉換接環,
相機的模組主要分成2個,除攝像部分(感光元件)外,
另一個是反光鏡,位相差AF及光學取景器部分,
看來這個模組化設計是為了讓將來M4/3相機也能使用4/3鏡頭時能進行位相差AF的設計,
也意味著是4/3系統消失後讓4/3系統鏡頭在M4/3上延命的對策
【公開番号】 特許公開2010-152140
【公開日】 平成22年7月8日(2010.7.8)
【発明の名称】 カメラシステム及び変換アダプタ
A camera body corresponding to a predetermined interchangeable lens and the above-mentioned predetermined interchangeable lens are camera systems which have a conversion adaptor for equipping with the above-mentioned interchangeable lens an interchangeable lens which differs in any they are at least and the above-mentioned camera body of shape of an applied part, and specification of control data,
The above-mentioned camera body possesses an image sensor for acquiring a picture based on light flux from a photographic subject,
The above-mentioned interchangeable lens possesses a taking lens to which light flux from a photographic subject is led,
The above-mentioned conversion adaptor,
A light flux dividing part which divides light flux from a photographic subject led with the above-mentioned taking lens of the above-mentioned interchangeable lens with which the conversion adaptor concerned is equipped,
A focus detection part which detects punctate [ on the above-mentioned image sensor of the above-mentioned camera body ] based on a part of above-mentioned light flux divided by the above-mentioned light flux dividing part,
An AF control part which performs a focus of the above-mentioned taking lens based on punctate [ which is detected by the above-mentioned focus detection part ] according to an AF control signal transmitted from the above-mentioned camera body,
A providing camera system.
[Claim 2]
The camera system according to claim 1, wherein the above-mentioned light flux dividing part is a half mirror.
[Claim 3]
The above-mentioned focus detection part passes through a pupil posion where the above-mentioned taking lenses differ, and phase difference data of an object image based on two or more light flux divided by the above-mentioned light flux dividing part is detected as the above-mentioned punctate,
The camera system according to claim 1, wherein the above-mentioned AF control part computes a defocusing amount of the above-mentioned taking lens and performs a focus of the above-mentioned taking lens based on a this computed defocusing amount from the above-mentioned phase difference data.
[Claim 4]
The camera system according to claim 3 after the above-mentioned AF control part's amending the above-mentioned phase difference data using correction value in which optional setting is possible with the above-mentioned camera body, wherein it computes the above-mentioned defocusing amount.
[Claim 5]
Correction value in which optional setting is possible with the above-mentioned camera body, The camera system according to claim 4 being the correction value for amending an image surface position gap between an imaging surface of imagination in which a part of above-mentioned light flux which was drawn with the above-mentioned taking lens and divided by the above-mentioned light flux dividing part carries out image formation, and an imaging surface which the above-mentioned image sensor has.
[Claim 6]
It is a conversion adaptor for the above-mentioned predetermined interchangeable lens to equip a camera body corresponding to a predetermined interchangeable lens with an interchangeable lens of shape of an applied part, and specification of control data in which any they are differ at least,
A light flux dividing part which divides light flux from a photographic subject led with a taking lens in an interchangeable lens with which the conversion adaptor concerned is equipped,
A focus detection part which detects punctate [ on an image sensor in the above-mentioned camera body ] based on a part of above-mentioned light flux divided by the above-mentioned luminous flux division means,
A providing conversion adaptor.
<參考>
E-5將是Olympus最後一台4/3相機??
43rumors.com
UPDATED-> (no rumor ranking) Quesabesde: The E-5 is the last FourThirds camera and there will be no more new FourThirds lenses (but will 43 continue to exist in a “different” way?)
http://43rumors.com/ft4-quesabesde-fourthirds-is-dead-the-e-5-is-the-latest-43-camera-and-there-will-be-no-more-43-lenses/
Zone-10 -> It is NOT predicting the end of FourThirds, just the merging of the technologies using modular construction and adaptors.
http://43rumors.com/zone-10-it-is-not-predicting-the-end-of-fourthirds-just-the-merging-of-the-technologies-using-modular-construction-and-adaptors/
43Rumors 消息-[FT4]43系統的變革
http://photofan.jp/camera/html/modules/newbb/viewtopic.php?viewmode=flat&topic_id=7527&forum=2
http://photofan.jp/camera/html/modules/newbb/viewtopic.php?topic_id=7527&forum=2&post_id=70958#forumpost70958
http://www.olympus.co.jp/jp/fun/wallpaper/camera/index.cfm?t=wp
上個月Olympus公開的3張新璧紙
分別是:
E-1 & M-1黑機身(試作品)
PEN E-P1 & Pen FT
M系統組合式相機MDN(試作品)
這樣的公開也許只是偶然,
或者....是在暗示接下來的產品是....
Olympus以前公開的 M系統組合式相機MDN(試作品) 相關璧紙
steadyandg
發表時間: 2010-07-16 23:21
發表數: 87
[71189] Re: Olympus 關於模組化相機的專利
我只希望開發出來後不要有公差 產生對焦的問題.... 4/3的鏡頭可以繼續用.....
發表時間: 2010-07-17 01:54
發表數: 6948
[71191] Re: Olympus 關於模組化相機的專利
這些圖看起來好像都是在講轉接環的部份
在轉接環裡加入CPU, 或是微鏡片組,以控制對焦機制。
這應該也不是啥專利或是機身模組化。(自己的規格用的轉接環還申請專利是要怎樣??)
至於還沒出機身就先想到4/3接環消失之後的4/3鏡頭的後路,那不是擺明了已經打算放棄了嗎?
就像當初FD被放棄的時候,也是出官方版轉接環在延續鏡頭生命阿!!
corpse
發表時間: 2010-07-17 05:38
註冊日: 2008-02-28
發表數: 471
[71192] Re: Olympus 關於模組化相機的專利
E5還是龜兵不出
我看43大概是玩完了
等有暑假完空就回來拋43,看來今年是閃人的末班車了
繼續回CANON好了,至少還有18-55IS二手可以買,便宜大碗能升級FF
還好當初太爛的沒拋,太好的也沒拋
我還有50F1.8、Tamron180、MPE65
135L可以用咧
發表時間: 2010-07-17 06:51
[71194] Re: Olympus 關於模組化相機的專利
這些圖看起來好像都是在講轉接環的部份
反過來想, Olympus 也許又走在時代的尖端了,
以趨勢看無反光鏡可換鏡頭相機可能會在不久的將來取代DSLR,
Olympus算是第一家已開始為將來DSLR鏡頭資產想出路的廠家了 ,
說不定將來其他DSLR大廠又會被這類專利卡住,
在無反光鏡可換鏡頭相機取代DSLR的時代來臨時,
無法讓自己用戶的DSLR鏡頭資產在無反光鏡的新相機系統上做有效的應用了
發表時間: 2010-07-17 07:16
發表數: 13222
[71195] Re: Olympus 關於模組化相機的專利
小弟的想法是,有沒有可能是,未來模組化的E-X,可以使用配件模組來改變構型.
裝上一些組件,它就變成相機的樣式,換上另一些組件,它又變成攝/錄影機的模樣,還可以選擇有無反光鏡光學取景系統
gundam
發表時間: 2010-07-17 12:49
註冊日: 2005-03-01
發表數: 627
[71197] Re: Olympus 關於模組化相機的專利
只是換模組和換機身的差異在哪裡?
這要定位出很棒的差異不容易.
如果是主要對焦模組和主架構保留共用,感光元件或是錄影套件可更換.
這個各主架構必須處理晶片需要合乎各種模組的應用需求才行,這樣在體積耗電能力下是很大的挑戰,且定價不可過高,又要能有多種模組可以更換,真的是很前衛的挑戰不容易
加油~
kshieh
發表時間: 2010-07-17 18:13
註冊日: 2009-01-06
發表數: 322
[71198] Re: Olympus 關於模組化相機的專利
往好處想, 只要價格不要太離譜, 就是買一台(套)機身同時可享用4/3的對焦能力與鏡群, 拆下後又可當m4/3輕便趴趴走. 我倒是很期待呢.
發表時間: 2010-07-17 20:05
發表數: 6948
[71199] Re: Olympus 關於模組化相機的專利
基本上
可換鏡頭的數位相機就是模組化的形式,鏡頭、記憶卡、電池、拍照方式(觀景窗或是LV)都可換,不就是模組化嗎??
再過分的模組化反而不必要
以RICOH GXR來看,消費者顯然不買單,因為模組化雖然帶來無限的可能,但也給消費者太多的不確定感,對整個後勤補給維修更是帶來災難。
當你用模組化的系統拍出有問題的照片,你會開始懷疑到底問題出在哪裡??
就像現在用CANON的相機拍出怪照片,有時候還要怪到記憶卡的不相容一樣。
如果是專業的用家,複雜度高的模組化系統絕對不是好選擇。
如果是業餘用家,我才不要拿這種系統來懲罰自己咧!~
yctai
發表時間: 2010-07-17 21:36
註冊日: 2008-08-06
發表數: 117
[71200] Re: Olympus 關於模組化相機的專利
不過模組化有一個缺點,就是體積很難壓下來,因為每個模組間都要有連接的機構,而且現在光是交換鏡頭這部分就一堆相容性問題了,要是連感光元件這邊也可交換,總覺得相容性問題應該會平方吧?
發表時間: 2010-07-21 03:49
發表數: 13222
[71227] Re: Olympus 關於模組化相機的專利
小弟看過這篇,在心裡一直想了很久.....
1.OLYMPUS MDN怎麼沒量產啊 實在太像是135版的HASSEBLAD了 135片幅有量產過一台模組化的SLR,是Rollei的3003,可是明顯的OLYMPUS MDN比較小巧啊
2.在下覺得OLYMPUS似乎真的想把感光元件模組化從機身切割出去變成機背了,就像是MDN的樣子.中間的那截,不是4/3-M4/3轉接環,而是對焦/取景模組啦 ,是否這就是4/3系統的未來方向 不知道這樣有沒有猜中OLYMPUS的意圖
stupid
發表時間: 2010-07-21 09:47
註冊日: 2008-09-05
發表數: 529
[71232] Re: Olympus 關於模組化相機的專利
好像sony/panasonic 一鏡二用的模式(dv/dc)比較簡單..體積也會較簡化
且之後對焦應該是對比式對焦的天下..因此把對焦模組抽出來
感覺沒什麼必要
發表時間: 2010-07-21 09:53
發表數: 13222
[71233] Re: Olympus 關於模組化相機的專利
stupid 寫道:
感覺沒什麼必要
不只是對焦,還有取景的方式啊.EVF及OVF可以選擇啊!然後感光元件因為這樣也有機會可以選用不同的方式.
grgeo
發表時間: 2010-07-21 23:13
註冊日: 2008-01-07
發表數: 199
[71247] Re: Olympus 關於模組化相機的專利
感覺比較像是過渡的一直方案
竊以為以後應該就會往對比對焦的方向發展了吧
charleswu
發表時間: 2010-07-21 23:28
註冊日: 2009-04-18
發表數: 292
[71249] Re: Olympus 關於模組化相機的專利
stupid 寫道:
感覺沒什麼必要
這種模組化的方式的確有蠻多想像空間的,也有蠻大的彈性去適應不同使用需求的人
只不過缺點就在於組合式的產品防滴防塵耐氣候的能力比較差,有相關需求的市場就吃不到了
還必須另外出一體式的機身才行
turtleknig
發表時間: 2010-07-22 00:10
註冊日: 2009-03-07
發表數: 151
[71250] Re: Olympus 關於模組化相機的專利
覺得模組化實在不適合台灣的「套餐」文化
可能很少人會花時間去思考「自己需要什麼吧」
nikon247
發表時間: 2010-07-22 09:09
註冊日: 2010-07-22
發表數: 134
[71257] Re: Olympus 關於模組化相機的專利
上面各位大大的看法都很有見地
小弟另外有2點疑惑
第一不知道這會定位在哪個層級
高階的話以目前情況應該是不可能跟上 C N 兩家
能齊頭D300S D700 及7D 就算不錯了
若是定位為入門至中階機種這層
價位的話依O家習慣可能又是不符期待
第二若只是為了整合 43 與 M43 的話
拆掉某些組件是M43系統
掛上某些套件可無痛接43鏡頭群
這樣的話跟目前一般同好除了大相機外還會有部隨身機的情形應該也是差不多了
一樣是要有2套鏡頭群...
這樣的創新作法不知道是不是真的符合整個趨勢....
yctai
發表時間: 2010-07-22 10:44
註冊日: 2008-08-06
發表數: 117
[71258] Re: Olympus 關於模組化相機的專利
正妹走進相機店:
正妹:我想買數位相機
店員:好的,這是O社新推出的『模組化彈性自由選擇相機系統』,最適合像小姐這種討厭套餐,完全知道自己需要什麼的人
正妹:那你介紹一下吧
店員:好的,首先您想要EVF或OVF呢?放大倍率要多少呢?
正妹:恩恩
店員:那您要AMOLED或OLED呢?
正妹:啊啊
店員:那您要選擇Kodak CCD或Panasonic LiveMOS呢?
正妹:恩恩
店員:那您要哪一個自動對焦模組呢?multi-cam 2000或3500呢?
正妹:啊啊
店員:那您要...
正妹:對不起我要去洗澡了
發表時間: 2010-07-22 10:49
發表數: 6948
[71260] Re: Olympus 關於模組化相機的專利
帥哥走進相機店:
帥哥:我想買數位相機
店員:好的,這是O社新推出的『模組化彈性自由選擇相機系統』,最適合像帥哥這種有型又有想法的潮男,完全知道自己需要什麼的人。
帥哥:那你介紹一下吧
帥哥:恩恩
店員:那您要AMOLED或OLED呢?
帥哥:啊啊
帥哥:恩恩
帥哥:唔唔
店員:那您要...
帥哥:算了!~來套5DII KIT 組吧!~
nikon247
發表時間: 2010-07-22 11:14
註冊日: 2010-07-22
發表數: 134
[71261] Re: Olympus 關於模組化相機的專利
CEO走進相機店:
CEO:我想買數位相機
店員:好的,這是O社新推出的『模組化彈性自由選擇相機系統』,最適合像您這種有創新概念又獨具慧眼,完全知道未來趨勢的人。
CEO:那你介紹一下吧
CEO:阿阿
店員:那您要AMOLED或OLED呢?
CEO:咿咿
CEO:唔唔
CEO:ㄟㄟ
店員:那您要...
CEO:OO~~~直接給我D3S就好了!~~~~
