 訪客: 168
center   討論區主頁 » Four Thirds System and Olympus SLR » Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)無發表權
發表時間: 2007-09-05 14:48
[32058] Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
德國 Color Foto雜誌2007 5月號的測試
Digital test to the Olympus E-400
用E-400測試19隻 Olympus及Sigma的4/3鏡頭,雖可付費下載但想到徳文還是看網路上的討論省些錢
Colot Foto 相關link (用altavista線上翻譯)
http://world.altavista.com/babelfish/trurl_pagecontent?lp=de_en&trurl=http%3a%2f%2fwww.colorfoto.de%2fobjektive%2ftestberichte%2fdigitaltest_an_der_olympus_e_400.150737.htm
L-camera 討論
http://www.l-camera-forum.com/leica-forum/digital-forum/22040-four-thirds-lens-review-german-colorfoto.html
其中穫得推薦有11隻鏡頭,ZD 150mm f2 92分最高,幾隻銀環上榜也不意外,Macro鏡也再次展現實力,到是 ZD 14-42mm 與 Sigma 18-50mm 以實用及小巧低價的到高分,只是同時擁有這兩隻鏡頭的用戶應該不多吧?
Olympus Zuiko Digital 2/150
92 - recommended
Olympus Zuiko Digital 4/7-14
87 - recommended
Olympus Zuiko Digital 2/35-100
87 - recommended
Sigma EX 2.8/105
87 - recommended
Olympus Zuiko Digital 3.5/35 Macro
86.5 of 150 points - recommended
Olympus Zuiko Digital 2.8/300
86 - recommended
Olympus Zuiko Digital 2/50 Macro
85.5 - recommended
Olympus Zuiko Digital 3.5-5.6/14-42
85.5 - recommended
Sigma EX 2.8/18-50 Macro
85.5 - recommended
Olympus Zuiko Digital 2.8/90-250
83 - recommended
Sigma EX 2.8/150 Macro
82.5 - recommended
QBEE
發表時間: 2007-09-05 15:48
註冊日: 2007-08-23
發表數: 37
[32062] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
4/3感覺顆顆是好鏡
錢砸下去都不會後悔
不過
好像沒看到自家50-200 還有SIGMA 24/1.8和 30/1.4這3隻哩...
gundam
發表時間: 2007-09-05 17:56
註冊日: 2005-03-01
發表數: 627
[32080] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
Olympus Zuiko Digital 2.8-3.5/11-22
85
"A less extreme wide angle zoom. At 11 mm, sharpness is limited to the center. Stopping down will not do a lot towards improving the edges. Quite good from center focal length upwards. Price is fair considering the 11-22 focal length range; on account of the problems at 11 mm, still no recommendation."
Olympus Zuiko Digital 2.8-3.5/50-200
83
"Tele zoom with reasonable speed and good performance up to medium lengths, even better when stopped down. At 200mm, contrast will break down pretty strongly, leading to a weak 73 points score at that length. Hence, no recommendation."
Olympus Zuiko Digital 3.5-4.5/40-150
83
"This economically priced tele zoom works well at the short end, but performance decreases significantly towards the tele end. At 150mm, contrast and resolution are visibly worse which precludes a recommendation. Stopping down drastically will improve performance, but using f/9 at 150mm makes precious little sense
Olympus Zuiko Digital 2.8-3.5/14-54
84.5
"The faster version of the standard zoom lens. In the tele range, good performance requires stopping down, thus partially obliterating the theoretical advantages. At 54 mm it reaches a mediocre 80.5 score - not recommended."
82.5 - recommended
"In direct comparison with the Oly 150, the Sigma is one stop slower and falls nearly 10 points short of the Oly's record score. While the Oly's performance is nearly independent of f stop, stoppind down the Sigma will improve contrast quite notably. Of course, price should be factored into the comparison: the Sigma will set you back only one quarter!"
Sigma 4-5.6/55-200
81.5
"The Sigma lens is the cheapest lens in today's roster. Also, it is the only lens that has visible lens centering problems. A second copy exhibited even worse centering problems, hinting towards a general problem in manufacturing. On the other hand, 150 euros is a super bargain price. Apart from the off-center lens problems, performance is satisfactory."
Sigma EX 1.4/30
69.5 of 150 points
"The Sigma lens is intended as a normal lens for APS sized sensors, and has shown to work quite well in that realm. For the smaller 4/3 sensor, results are less encouraging. Contrast wide open is moderate at best, with a notable decrease towards the corners. Stopping down improves the overall impression notably, and still makes a rather fast lens at 2.8".
Sigma EX 2.8/105
87 - recommended
"Actually a 24x36 lens, this lens is very sharp over the full area of the smaller 4/3 sensor (as can be expected). Stopping down will further increase sharpness. This helps both in scoring and in getting a clear recommendation
steadyandg
發表時間: 2007-09-05 19:43
發表數: 87
[32086] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
蠻令人吃驚的
熱門鏡 好像都不推薦
冷門鏡 好像有點出頭的感覺 哈哈哈
18-50 我來了.....
morlin2001
發表時間: 2007-09-06 00:13
註冊日: 2007-02-26
發表數: 33
[32100] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
Leica D Lens 呢?
目前市面上有兩顆...
難道被遺忘了嗎?
發表時間: 2007-09-06 01:22
[32113] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
ZD50200因為200mm端對比驟降被大扣分掉出recommended
發表時間: 2007-09-06 08:28
[32132] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
不過單看分數的話卻又挺接近的,
我想作測試嘛....沒辦法每支超過80分就推薦,
只好找些理由篩掉一些鏡頭....
弄到最後上榜的不是銀環鏡就是微距鏡
leeleoleo
發表時間: 2007-09-06 08:29
註冊日: 2007-01-08
發表數: 51
[32133] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
Sigma EX 2.8/105
分數比
還高分咧,差異是在哪?
西平英生2005-07鏡頭評鑑
Sigma EX 2.8/150 Macro---★★★★★
Sigma EX 1.4/30是真的不好
cw.wang
發表時間: 2007-09-06 13:03
發表數: 194
[32168] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
Pussycat 寫道:
在另一篇九月號的評比中,50-200 又被列為前五名的變焦鏡......
看來這些媒體的話真是要斟酌參考......
gundam
發表時間: 2007-09-06 13:17
註冊日: 2005-03-01
發表數: 627
[32171] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
參考就好,別太認真~
該評比可能只衡量到畫質 和畫面反差對比,至於色澤和焦段的使用方便性沒有佔很大的比重.
像是14-54mm + 50-200mm不知道多少E-1的寫真專家拿來拍出多少好作品.(好照片產量蔗各組合應該是最高的).
當然要做出十全十美的評比也很難,
你只要抓出每份評比的公平性和主要評比著墨的衡量點是哪些?而這些重點是不是你在意的就好.
發表時間: 2007-09-06 13:21
[32175] Re: Color Foto 雜誌測試 19 隻 4/3 鏡頭 (2007 5月號)
cw.wang 寫道:
Pussycat 寫道:
這是因為只比較望遠變焦鏡時,評比對像不同的結果,可惜無法找到相關望遠變焦鏡測試的評論 (雖然沒有在19隻4/3鏡評測中被推薦,50-200的分數仍是相當高的)
