Leica D SUMMILUX 25mm/F1.4 ASPH | 無發表權 |
| masaru | 發表時間: 2006-09-26 19:35 |
Quite a regular ![]() ![]() 註冊日: 2005-06-22 來自: Taipei 發表數: 128
[17994]
Leica D SUMMILUX 25mm/F1.4 ASPH http://www.four-thirds.org/en/products/single.html#pana25
25/1.4 這麼早就上 Catalog, 難道就要發表了... ![]() ![]() ![]() This lens, which features 10 lens elements in 9 groups, including one large-diameter aspherical lens, combines outstanding F1.4 brightness at maximum aperture with an exceptional optical performance. The use of one Super ED lens and three ED lenses suppresses chromatic aberration to minimize color bleeding. A floating focus system allows macro shots at a closest focusing distance of 38 cm. An aperture ring on the lens barrel gives this lens, when mounted on the LUMIX DMC-L1, a familiar analog operating feel. ●Lens construction = 10 elements in 9groups ●Closest focusing distance = 0.38m / 14.96in ●Maximum image magnification = Apporox. 0.18x (35mm film camera equivalent) ●Filter size = 62mm ●Dimensions =φ77.7mm / 3.06in ●Weight = 525g / 18.5oz ●Accessories = Lens Cap, Lens Hood, Lens Rear Cap, Lens Storage Bag 後記: 開啟 4/3 Lenes Catalog 的定焦鏡, 看到 24/1.8 25/1.4 30/1.4 這樣一路排下來, 突然有種幸福的感覺... 抱歉,主題跟 menestrel 兄重複,真是不好意思。 |
| 怪異模型師 | 發表時間: 2006-09-26 20:32 |
[17998]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 要嘛不來,要來就一次來一堆...啥鬼
需要超大光圈快速對焦的選30mm F1.4 需要標準焦段以及MACRO兩用的選24mm F1.8 需要高品質表現的就當然是選25mm F1.4 這下子選擇突然變多,真是糟糕啊 |
| collective | 發表時間: 2006-09-26 21:08 |
[18001]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 引文:
10枚9群的標準鏡頭 又是ED又是非球面的,濾鏡口徑還是62mm 真是奢華的設計 |
| olps | 發表時間: 2006-09-26 21:26 |
Quite a regular ![]() ![]() 註冊日: 2005-11-16 來自: 發表數: 102
[18003]
| Pussycat | 發表時間: 2006-09-26 23:04 |
[18012]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 只能確定很容易做bokeh...
| kwsu | 發表時間: 2006-09-26 23:05 |
Not too shy to talk ![]() ![]() 註冊日: 2006-03-05 來自: 發表數: 14
[18013]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 唉..... 開始有大光圈定焦鏡可用 但 荷包裡的銀兩也要耗損不少吧 |
| roxin1 | 發表時間: 2006-09-26 23:08 |
Quite a regular ![]() ![]() 註冊日: 2006-08-11 來自: 發表數: 55
[18014]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 不知售價如何?
如果三萬以下就衝了....... (人生第一支徠卡,我來了......幻想中) |
| 689230018 | 發表時間: 2006-09-26 23:30 |
[18020]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 售價不知道會不會與 M SUMMILUX 50/1.4 ASPH 看齊
如果又是一支天價的鏡頭的話,還是用SIGMA 吧 |
| 菊草葉 | 發表時間: 2006-09-27 00:28 |
Quite a regular ![]() ![]() 註冊日: 2005-06-04 來自: Pokemon 發表數: 139
[18023]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 25/1.4: 變形雙高斯設計(double-gauss) 24/1.8: 逆焦式設計(Retrofocus) 30/1.4: 變形雙高斯設計(double-gauss) 原來E系統的第二章是...大光圈定焦鏡頭....嗎....^_^ 25/1.4這支鏡頭應該會是Panasonic代工,價格可能會低一點吧,我猜可能在2.5 - 3萬元左右... |
| sohoming | 發表時間: 2006-09-27 00:38 |
[18026]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 為什麼原廠不出一支便宜的25mm/1.8 ?
萊卡太貴, sigma鏡身質感小弟也不太喜歡 為蝦米..... |
| 無名 | 發表時間: 2006-09-27 00:53 |
Quite a regular ![]() ![]() 註冊日: 2005-07-03 來自: 發表數: 51
[18028]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 我怎麼看
我們好像是在C,N家�堶掖� 有一堆鏡頭讓我們看的目不暇給 不知要哭還是要笑ㄋ |
| side7 | 發表時間: 2006-09-27 01:05 |
Not too shy to talk ![]() ![]() 註冊日: 2006-08-10 來自: 發表數: 31
[18029]
嗯... 請問文中提到的 "變形雙高斯設計(double-gauss)" 與 "逆焦式設計(Retrofocus)" 是指什麼樣的設計呢? |
| collective | 發表時間: 2006-09-27 06:19 |
[18039]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH Leica D SUMMILUX 25mm/F1.4 ASPH的光圈調整環在鏡頭前面耶
和OLYMPUS OM ZUIKO鏡頭一樣 |
| s8131556 | 發表時間: 2006-09-27 11:28 |
Not too shy to talk ![]() ![]() 註冊日: 2006-06-24 來自: 發表數: 25
[18048]
剛才去問了咕狗大神 他說 雙變形高斯設計 參考一下囉~ |
| Pussycat | 發表時間: 2006-09-27 11:51 |
[18049]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH 在Photonika現場展示啦...
http://dc.watch.impress.co.jp/cda/other/2006/09/27/4703.html |
| ITO | 發表時間: 2006-09-27 12:11 |
[18050]
在日本有些測試報告 例如 http://dc.watch.impress.co.jp/cda/longterm/2006/08/09/4393.html 有批評Leica 14-50的光圈調整環位置不方便使用,所以25mm才如此設計的吧 |
| ITO | 發表時間: 2006-09-27 12:14 |
[18051]
預定明年春天上市,價格未定 |
| 菊草葉 | 發表時間: 2006-09-27 12:17 |
[18052]
變形雙高斯是日本人愛用的名詞,LFC的說法是非對稱雙高斯結構,也是相當清楚的說法。基本上在35mm相機中的大光圈定焦鏡頭有許多名鏡都是採用變形高斯結構設計的,包括LEICA和ZEISS在內都是。日廠更不用說了,50mm標準鏡頭幾乎全都是變形高斯設計。 變形高斯設計在1980年代後就已經少有改良。原因為何?記得曾在Erwin Puts的newsletter中讀到ZEISS的設計師對此提出過個人看法。他提到CONTAX的PLANAR 50mm是可以在進一步改善光學表現的,但為了校正像差,唯一的方法就是使用更多鏡片和更昂貴的玻璃材料,但CONTAX並不想讓鏡頭售價變貴,所以還是維持傳統的老設計。日本其他廠商對50mm的設計也都停滯不前,原因很多,除了成本之外,50mm的變形雙高斯結構的表現已經算夠好的了,所以除了限量版鏡頭外,大家都不太願意改良舊版。 只有LEICA比較龜毛一些,一直到最近這一,還不斷推出50mm的改良版,主要是APSH化以及使用更多的校正像差鏡片(結果也越來越貴就是了......)。現在數位攝影時代來臨,FourThirds系統終於有新的標準定焦鏡頭了,看設計圖上,25mm鏡頭應該還是使用變形雙高斯,但在設計上有不少改良之處,影像表現可能會大幅強化。 至於逆焦式(Retrofocus)最早應該是愛展能發明的一種廣角鏡頭設計,將一組高倍率凹透鏡組(negative group)放在凸透鏡組(positive group)之前;鏡頭的實際焦長比後焦距長度要短。基本上是把Telephoto的設計逆轉過來,所以也叫「逆伽利略」設計。在有反光鏡設計的SLR上,廣角鏡頭的後鏡組無法像Biogon基本設計那樣深入機身(會被反光鏡打到,或者遮住機身內部的測光元件)。 Wiki的解釋: http://en.wikipedia.org/wiki/Retrofocus 比較不瞭解的是FourThirds系統允許25mm仍用變形雙高斯,但Sigma的24/1.8仍用逆焦設計的原因何在?也許Sigma的24/1.8是沿用35mm全幅的設計(僅是個人猜測而已...) |
| DIC | 發表時間: 2006-09-27 12:29 |
Not too shy to talk ![]() ![]() 註冊日: 2005-08-31 來自: 發表數: 50
[18054]
因為Summilux 25mm F1.4 是一顆視角為標準的鏡頭,而SIGMA 是要一魚多吃,4/3,它是顆標準,在APS-C,它是一顆廣角,在135FF, 它是一顆超廣. |
| ITO | 發表時間: 2006-09-27 12:36 |
[18055]
Re: Leica D SUMMILUX 25mm/F1.4 ASPH http://www.digitalcamera.jp/
2006/09/27(水) http://www.digitalcamera.jp/html/HotNews/image/2006-09/27/pana-01-L.JPG http://www.digitalcamera.jp/html/HotNews/image/2006-09/27/pana-02-L.JPG http://www.digitalcamera.jp/html/HotNews/image/2006-09/27/pana-03-L.JPG http://www.digitalcamera.jp/html/HotNews/image/2006-09/27/pana-04-L.JPG ![]() ![]() ![]() ![]() |
| (1) 2 3 4 ... 8 » | |
